Turntable suggestions
0 Members and 1 Guest are viewing this topic. Read 5932 times.
rooze
Re: Turntable suggestions
« Reply #20 on: 7 Dec 2019, 09:43 pm »
If you want to try something different (something other than VPI) then you could score a Music Hall MMF11 for well below your budget. (I happen to know where, in fact  :wink: )
I moved from an older VPI TNT to the Music Hall and much prefer its sound over the VPI.
YMMV.
Rooze
***OOPS, sorry, I just noticed you'd found a TT - congrats, good choice***
jawks
« Reply #21 on: 7 Dec 2019, 10:18 pm »
YMMV.
Rooze
Thanks for the reply!
SteveFord
« Reply #22 on: 8 Dec 2019, 01:35 am »
I'm looking forward to your thoughts on the Well Tempered.
jawks
« Reply #23 on: 8 Dec 2019, 01:47 am »
Thanks! I will try to post my impressions once I’ve had some time with it!
Not Insane
« Reply #24 on: 10 Dec 2019, 02:46 pm »
I just have to say something about the "high end" label.
It's subjective. I like to compare stuff like this to something everybody understands - Cars.
Entry level TT (under $300). Think Trabant.  It will get you there, but it might not be worth the trouble. You may want to save up for something better:
1. Crosley Cruiser.
2. The Audio Technica ATlP60 would be a much better choice.
3. The new cheapie belt drive Crosley and Dual (they are the same table) that look kinda like a Technics 1200 may be a much better choice as well.
Mid-level: Toyota Corolla (with Leather seats) or Buick/Chevy similarly loaded.
1. the Under $600 U-Turn, Pro-ject, Fluance and the rest of the belt drive stable.
2. The Audio Technica ATLP120 group and their equivalent Hanpin direct drive model in other brands.
High End: BMW, top end Volvo, Accura, Cadillac(?), Corvette, Porsche Cayman, Lexus
Turntables better than Mid-level and less than around $2,500.
Exotics:Aston Martin One-77, Lamborghini Veneno, Pagani Huayra, Ferrari F60 America
For turntables, this is the stuff that most humans on the planet see in the same way they see the cars listed above. They're cool, but not only too expensive, but not a practical solution to their situation.
A simple example: I have a 150 mile round trip commute on some of the most fun twisties in the US. I've been through 8 sets of tires, mostly Michellin PSS's, on a Scion FR-S. It is beyond fun. The car now has 180k miles on it with no end in sight. Even if I could have afforded it, I would not have wanted a Huayra for this commute. Those cars are not designed to be driven hundreds of thousands of miles. They are designed to be driven occasionally and marveled at by passers by. And though they are a LOT of fun to drive, most people can not justify their cost when applied to their needs in a car.  And I can get my bass and an amp in my FRS and still have a blast.
I love to look at exotic turntables. I love to go to audio shows and marvel at the top notch stuff. I visited the show in Chicago last winter. It was a lot of fun. But since my income is only six figures, I can't justify the stuff.
Exotics are for a certain income level or commitment to the equipment. It usually takes both, but if you are an oil baron, it only takes the former. :)
Once you go over $1500 for a turntable and $500 for a cartridge, you start hitting a wall called the point of diminishing returns. That is where you get into the realm of "exotics".
FWIW, every single person I've rubbed shoulders with my entire life, with the exception of my friend that works at Difinitive Audio in the Seattle area, would laugh at anyone paying five figures for a record player. It doesn't mean they are right that it's funny, but it points out that you are definitely in the realm of an "exotic" product at that price point. Think of it as "the one percent". ;)
But like I said, those labels are subjective. I just moved to an area where "suite" is pronounced, "suit". I'm sure most of the folks around here would consider a Fluance an "exotic".
mkane
« Reply #25 on: 10 Dec 2019, 09:51 pm »
  I'll let you know if my exotic sounds better that my mid-level after it arrives.
revrob
« Reply #26 on: 12 Dec 2019, 10:15 pm »
Music Direct has a VPI Prime Scout B-stock for $2k, add a cartridge for $500 and you got a great system.
https://www.musicdirect.com/turntables/VPI-Prime-Scout-Turntable-with-JMW-Metal-Tonearm-Armwand-9-B-STOCK
jawks
« Reply #27 on: 12 Dec 2019, 10:24 pm »
Thanks!  I did see that deal but decided to get a used Well Tempered Amadeus mk2.
revrob
« Reply #28 on: 12 Dec 2019, 10:34 pm »
Great table. Enjoy the journey. I just picked up a used VPI Classic Signature that came with the SDS, Clamp, ring, and dust cover for $3k. Best purchase I ever made. Good luck with your table.
sebrof
« Reply #29 on: 13 Dec 2019, 02:44 am »
Thank you ALL for your insight and input!  While I did consider reacquiring a used VPI Aries, I decided for a change of pace and purchased a very lightly used and near mint Well Tempered Amadeus mk2 that recently came up for a very reasonable price and under my price threshold.  I'm new to the WTL turntables but have heard and read lots of very positive feedback about their sound, so I'm eager to hear how this sounds in my system!
Thank you again!
I have a WTL Amadeus MK2 as well, I love the table. If you have questions about it go over to the WTL circle here on AC and ask away, some pretty knowledgeable owners over there. Good luck.
jawks
« Reply #30 on: 13 Dec 2019, 02:46 am »
Thank you very much! Looking forward to joining that circle soon!
undertowogt1
« Reply #31 on: 13 Dec 2019, 02:37 pm »
There are three things you can do with Money Save it, give to Charity and Spend it (Dave Ramsey). As long as you do those three things I say by a "high End " table. Nice choice with the WTL
jawks
« Reply #32 on: 13 Dec 2019, 02:40 pm »
I'll second that notion!  Happy holidays!
