0 Members and 1 Guest are viewing this topic. Read 5916 times.
Rega Planar 6?The new Technics $1200 model?
Haha - thanks for the correction! Yes, mid-level, rather than high-end, is what I meant to say.How does the Aries III compare with the Aries I or other VPI models such as the Scout, Classic, Scoutmaster, Prime, etc? There are a lot of VPI table names - it's hard to keep track.I have eyed the Technics SL-1200G and had a chance to listen to it briefly at a high-end shop in town. It's also pretty impressive, though I'm not sure I'd be willing to spend $4000 for it.
every bit as good as the Prime IMO, I doubt very much if you could hear a difference but I have never compared anything side by side to my Aries III.As for the 4k price on the 1200G, that's msrp, never pay msrp ! While I've yet to see 20% off I have seen up to 15%
I forgot to mention that I once owned a RP6 when my Aries was in storage for a year or so but sold it. Which Technics are you referring to?
first off $2500 is not likely considered 'high end', middle of the road at best, but that's Ok !!You liked your VPI Aries1, may I suggest a nice used Aries III with a 10.5i arm. That's what I use and have zero desire to change but if I did I'd buy a Technics 1200G and call it a day ...........
You should be able to get a new WTL Simplex MKII for around $2500.
Thanks! I was thinking about a used Amadeus mk2, which had received very positive reviews in the past. I’m n not sure how the Simplex compares with the Amadeus. Have you owned either of these?
Hey! $2500 turntable? Well, that's "high end" to me! So, at what price point a turntable could be consider a "high end" turntable?
Yes I would also like to know what a high end turntable is as well. It is a price point or quality because $2500 can buy a heck of turntable especially if you buy used and I definitely wouldn't call it mid-fi. The VIP turntables have been know to represents great value at their price points.
For $2500 go find another used Aries. That table is awesome and getting something new for the same money won;lt give you the same performance as that Aries. Set it up with one of the newer VPI tonearms (fatboy) and you are set for life.
