I need an amp up to $500 (new or used) to go with JBL Studio 530 Speakers.
maty
https://www.google.com/search?q=audiosciencereview.com+ljm+l12-2+maty
-> https://www.audiosciencereview.com/forum/index.php?threads/chinese-jl-hood-1969-class-a-amplifier-off-aliexpress.3372/post-269888
by bunkmail, today
-> https://www.audiosciencereview.com/forum/index.php?threads/icepower-125asx2-class-d-amplifier-review.10442/post-287842
Agreed, it's horrendous. You can get far better performance at ~$200, for example LJM L12-2 power amp, 120W @ 8 ohm, 200W @ 4 ohm (THD 0.0005% 1kHz at 10W). I own a unit and it sounded absolutely glorious with my Wharfedale EVO 4.2 speakers (I'm totally not biased btw).
Wharfedale EV= 4.2
https://www.wharfedale.co.uk/evo4-2/
https://www.audiosciencereview.com/forum/index.php?threads/neutral-bookshelf-speakers-2000.9546/post-264214
Bought a factory refurbished Harmon Kardon receiver years ago, loved the sound and the price.
ketcham
estate sales are wonderful resources.  McIntosh for the cheap.  Other excellent brands.  More vintage the better.
reillyzing
Charles Calkins
     I bought a Rockville RPA9 amp on Amazon. $159.99. I'm using it in a patio system.
     Works fine. You might give this amp a look on Amazon.
                                                       Cheers
                                                       Charlie
pinkfloyd4ever
There's usually even more good used stuff in your price range on US Audio Mart, and to a lesser extent, eBay and audiogon, if your budget is now up to $500. NAD and Adcom offer great bang for the buck for used gear in the $300-500 range.
We're upon one of the best times of the year to get nice used stereo gear.  Many people who get new equipment for Christmas will be selling off their old gear on the secondary markets in the next few weeks. Make it a habit to check USAM (assuming you're in the US), as well as ebay and your local CL and FB Marketplace on a daily basis. Also set up some HiFi shark alerts if you find some specific model numbers you want to look for. Good luck!
witchdoctor
What amp did you eventually get?
reillyzing
Still nothing. I did a lot of reading about older amps from Carver, Adcom, etc., but am hesitant to buy due to the possibility that repairs will be necessary.. What are the chances a 25-30 year old amp is still functioning as it should? And as a novice, I wouldn't know what to look for in terms of failing parts.
witchdoctor
Paralysis through analysis  :o
witchdoctor
Check out the Klipsch Powergate thread here on Audiocircle:
https://www.audiocircle.com/index.php?topic=162664.0
Mr Rick
Why not try something from Emotiva like the A-100, or A-150. Both are available on Amazon, and are within your budget.
reillyzing
I bought a used NuForce STA200. I probably have less than forty hours on the JBL's. My impression so far is they're a fairly decent match. Of course, as I mentioned already, my experience with speaker systems is very limited. The only comparison I can make is with AudioEngine A5+ active speakers, which have a pleasant, unfatiguing sound, but the JBL's are more resolving and have much, much nicer bass.
My only complaint is, the higher frequencies could use some taming at times when listening to certain rock albums.. I'm also running my setup out of a desktop pc for the time being, which I know isn't ideal.
Edit: Sounding better after switching from Foobar to HQPlayer.
« Last Edit: 28 Jan 2020, 07:10 am by reillyzing »
maty
I bought a used NuForce STA200. I probably have less than forty hours on the JBL's. My impression so far is they're a fairly decent match...
https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-nuforce-sta-200-power-amp.5039/
witchdoctor
Congratulations! My JBL 230's sounded better placed on Isocoustic stands:
witchdoctor
As for sounding bright try turning them upside down so the tweeter is on the bottom and compare.
reillyzing
Thanks, I use a pair of Auralex Mopads that are about ten years old now.
grubyhalo
Here's my recommendation:
https://www.allo.com/sparky/volt-plus-d-amp.html
I use one with a Nuprime DAC-9 driving an 86db bookshelf monitor and it sounds fantastic. I used this cable when I first bought the amp and thought the system sounded pretty good: https://www.parts-express.com/audtek-electronics-skrl-12-50-12-awg-ofc-speaker-wire-50-ft--100-024
Then I got this one and the sound quality went up appreciably:
https://www.parts-express.com/mogami-w3103-superflexible-high-definition-2-x-12-awg-speaker-cable-1-ft--103-1023
Just my 0.02, YMMV...
