Introducing the Sonore microRendu v1.5 - new design
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
The original Sonore microRendu v1.3 was discontinued in March 2020 because certain parts on the unit were becoming hard to get. Soon afterward we decided to redesign the unit improving some components and upgrading others. Another key goal of the project was to reduce the price without compromise to the performance. With a little bit of hard work we were able to achieve all the project goals and we think you will be thrilled with the Sonore microRendu v1.5.
So what's new?
1. Improved two power converters and their associated capacitors using some new ones that are much
better than what we had years ago. The result is significantly better power network performance.
2. Improved the clock buffer to one used in opticalRendu. This part has MUCH lower jitter.
3. Improved the USB A jack to the through hole one used in other Rendu boards. This was done to increase reliability.
4. Ships with Sonic Orbiter 2.8.
5. New lower price.
SELECTABLE OUTPUT MODES
Mode #1 - SqueezeLite Output - This output works with any Logitech Media Server and compatible controllers. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #2 - ShairPort Output - This is an AirPlay emulator that utilizes streams sent to it from a compatible source. This output supports true gapless playback of PCM.
Mode #3 - MPD/DLNA Output:
Mode #3a - DLNA Output - This output utilizes streams from UPnP/DLNA servers and controllers. This output can be configured as an OpenHome renderer. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #3b - MPD Output - This output is intended to work with an SMB mount. This output supports true gapless playback of PCM, DSD/DoP, and native DSD. This option requires an SMB share to mount your content in combination with the built-in Drive Mounter application.
Mode #3c - Songcast Output - This output accepts streams from your computer running Linn Songcast. The application is in Beta form.
Mode #4 - HQ Player NAA Output - This output utilizes streams from Signalyst's HQ Player running on your computer. Digital signal processing is performed by HQ Player and then asynchronously streamed to the Network Audio Adapter (NAA) output. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #5 - RoonReady Output - This output utilizes streams from Roon. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #6 - Spotify Connect Output - This output can be controlled by your computer or tablet running the Spotify (premium) application. This application is based on librespot - an open source client library for Spotify. The application is in Beta form.
Availability
https://sonore.us
« Last Edit: 14 Nov 2021, 04:45 pm by vortecjr »
