Sonore opticalRendu - fiber optic Ethernet to USB-Audio
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
The Sonore opticalRendu project is an extension of the microRendu and ultraRendu projects that came before it. The design is inspired by audiophile gear and meant to bring grace and simplicity to a microcomputer. The original microRendu was very small and intended to be hidden out of sight behind your other gear. The opticalRendu can be powered by your favorite power supply. The opticalRendu has optical Ethernet input and USB-Audio output with all the connectors located on the rear of the unit for easy cable routing. The opticalRendu utilizes a new proprietary printed circuit board with only the essential components and many updates to match its optical designation. The best way to connect the opticalRendu to a USB device is via your favorite USB cable. The opticalRendu is easy to configure, accepts streams from various sources, and includes our latest version of our operating system Sonicorbiter.
SELECTABLE OUTPUT MODES
SqueezeLite Output
ShairPort Output
MPD/DLNA Output:
HQ Player NAA Output
RoonReady Output
Spotify Connect Output (beta)
SOFTWARE FEATURES
Supports the following PCM sample rates up to: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz, 705.6kHz, and 768kHz
Supports the following DSD sample rates up to: DSD64, DSD128, DSD256, DSD512
POP free DSD/PCM transitions
Not all USB devices or output modes support the maximum sample rate of the unit
RoonReady certified
Audirvana Plus certified
Running Logitech Media Server locally allows playback of local radio stations and streaming service
Logitech Media Server allows you to use the unit as a UPNP server in combination with Drive Mounter
The Software Manager that allows you to install and uninstall apps as needed
BubbleUPnP Server app allows any renderer to take advantage of the OhMedia - OpenHome protocol
OhMedia - OpenHome protocol allows the Linn Kinsky and Linn Kazoo Apps with playlist support to be used as controllers
Supports Tidal and Qobuz lossless streaming in Squeezelite output mode and DLNA output mode
Native DSD is supported on select DACs
The unit is controlled via third-party apps on your mobile device and on your computer
Based on Sonicorbiter, closed source and open source (GPLv2)
HARDWARE FEATURES
Eleven (11) high-quality ultra low noise linear regulators
Two (2) fixed frequency high-quality ultra low jitter FEMTO oscillators
External power input jack
SFP cage / SFP optical transceiver for network connection
USB-A audio output connector
Micro SD port for the operating system
Multicore processor with DDR3 RAM
Power input: 2A peak current and 1.5A continuous current at 6-9 VDC output
Power connector: 2.1mm x 5.5mm (center +)
Dimension without rubber feet: 1.181"(H)x4.331"(W)x4.409"(D)
The opticalRendu is systemOptique Certified.
AVAILABILITY
https://sonore.us
« Last Edit: 3 Dec 2019, 02:17 am by vortecjr »
