Sonore Signature Rendu SE - single enclosure opticalRendu / linear power supply
vortecjr
  • the sound has to be in concert with the music....
    • Sonore by Simple Design
***The Signature Rendu SEoptical received the 16th Annual Positive Feedback Writers' Choice Awards for 2019***
Introducing the Signature Rendu SE, the absolute finest streaming USB source we have made. The Signature Rendu SE is the natural evolution of Sonore’s ultraRendu and Sonore’s acclaimed Signature Power Supply.
The Signature Rendu SE takes fiber optic Ethernet input or cable ethernet input and renders it to a perfect, ultra-low noise USB feed to one’s USB DAC. While the opticalRendu is a revolutionary product, the Signature Rendu SE takes off from the opticalRendu concept, improving on it by refinement and attention to every detail. The SE takes advantage of single chassis design, allowing close coupling of the power supply and processing board for the ultimate in ultra-low impedance and ultra-low noise power delivery. The SE processing board uses a large footprint to allow for eleven (11) independent low noise voltage regulation stages, and better physical separation of the Ethernet processing and USB output sections, further reducing noise and crosstalk. Two ultra-low phase noise (so-called “femto”) oscillator are used to govern all processing and USB audio output.
SELECTABLE OUTPUT MODES
Mode #1 - SqueezeLite Output - This output works with any Logitech Media Server and compatible controllers. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #2 - ShairPort Output - This is an AirPlay emulator that utilizes streams sent to it from a compatible source. This output supports true gapless playback of PCM.
Mode #3 - MPD/DLNA Output:
Mode #3a - DLNA Output - This output utilizes streams from UPnP/DLNA servers and controllers. This output can be configured as an OpenHome renderer. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #3b - MPD Output - This output is intended to work with an SMB mount. This output supports true gapless playback of PCM, DSD/DoP, and native DSD. This option requires an SMB share to mount your content in combination with the built-in Drive Mounter application.
Mode #3c - Songcast Output - This output accepts streams from your computer running Linn Songcast. The application is in Beta form.
Mode #4 - HQ Player NAA Output - This output utilizes streams from Signalyst's HQ Player running on your computer. Digital signal processing is performed by HQ Player and then asynchronously streamed to the Network Audio Adapter (NAA) output. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #5 - RoonReady Output - This output utilizes streams from Roon. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #6 - Spotify Connect Output - This output can be controlled by your computer or tablet running the Spotify (premium) application. This application is based on librespot - an open source client library for Spotify. The application is in Beta form.
Availability
https://sonore.us
« Last Edit: 5 Jun 2021, 07:51 pm by vortecjr »
