0 Members and 1 Guest are viewing this topic. Read 24408 times.
from your description, it sounds like yure talking about what folks call the ack! 1.2 wersion.
yure the 1st person i've heard who sez even this iteration is more detailed/dynamic/extended than a modded di/o. makes me even *more* anxious to hear a 2.0!
.....I'd say that the 2.0 with cap upgrade will give you everything you like about the DI/O but with a smoother and more involving mid-range, lower noise floor, and higher resolution in the top end.
Well, it wasn't in its stock form. Originally the bottom end was not as extended or as tight as the DI/O, and the highs were slightly rolled off. The cap changes made all the difference. I'd say that the 2.0 with cap upgrade will give you everything you like about the DI/O but with a smoother and more involving mid-range, lower noise floor, and higher resolution in the top end.
have ya ever heard the 2.0 compared w/your 1.2 (or is it 1.3?).
it seems that what ya said prewiously about how much ya like yer modded older ack!, this may in fact *also* give me what i like about my di/o, along w/the ack!'s benefits.
and, since the 2.0 has been introduced, the earlier ack!'s are a relative bargain on the used market.
