0 Members and 1 Guest are viewing this topic. Read 24758 times.
What is all this discussion about the Ack Dack output? My integrated is rated: "250mV / 25kohm / Phono". Will I need a High Output option added to my Ack Dack 2.0 that I want to order?
What is all this discussion about the Ack Dack output? My integrated is rated: "250mV / 25kohm / Phono". Will I need a High Output option added to my Ack Dack 2.0 that I want to order?...
rmihai0,...Most audiophiles I know listen at or below 80 dB (as they should because continued exposure to 85 dB will result in permanent hearing loss or worse). With 90 dB/w/m efficiency speakers that would translate into using just 0.1 watts/channel. Of course its the peaks that demand "real" power.
... I let my Bolder Teac run in 22/7...for over 30 days straight, to come up with the over 700 hours of prescribed break in - the treble would come and go during that time, and so it was a real chore, but now that it is the books... quite pleased.Hang in there guys, and try to find a way to get long hours on your gear early, so that you can start enjoying it faster!
It's very hard to burn in an Ack Dack, without risking injury to the batteries. You have to be there to physically turn it off. Heck, there have been quite a few times when I've forgotten to turn my version 1.x off, so I never even attempted to burn it in.
...jus no way i wanna give up what the di/o does so well, & even the folk who prefer non-oversampling dacs like the earlier ack!, scott nixon, etc., say that the di/o has better dynamics, detail & frequency extension.but, until this dac is offered w/a way to hook up an ac power supply that automatically swi ...
Hi Doug,The DI/O certainly gave an idea of what a inexpensive well-designed DAC with good sounding conversions chps and a decent output stage (and ADC) could do. It was not without its own issues (high output overloading preamps, phono plug outputs instead of RCA, spuriuos noise sensitivities to AC line quality). Despite this it was able in stock form to present a level of dynamics and detail that many felt welcoming.For DIY types (like you and I) that previously mentioned issues can be rectified(is ...
Doug,I have a Bolder modded Art DI/O with his power supply that uses his Nitro cable on it.I also have a first generation Ack dAck that I have made minor mods to. The mods involved chunky the 3.0uF Auricaps for 3.3uF Sonicaps and adding .01uF Teflon film and foil by-pass caps. It's the same by-pass caps Chris offers as an upgrade on the new model. The by-pass cap was a biggy. A minor mod that I left in was adding the Bybee filter on the data input.The Ack dAck now has good extension to the top e ...
