0 Members and 2 Guests are viewing this topic. Read 22699 times.
...The ClarityCAP CSA alone is natural but edgy, definitely not good. The ClarityCAP CSA+KZK K78-34+Miflex KPCU-01 gives the best harmony. I also tried only the ClarityCap CSA+KZK-K78-34 but was missing the micro detail with the soundstage and the global warmness. Yes, the Miflex is very important and with such a small value is a strong influencer in the sound.The result:Extremely butter-liquid-silky smooth with huge soundstage, with rich organic micro fine detail. Unbelievable experience. We listened many different kind of music, classical, jazz, disco, latin and simply fantastic. We always turn the volume up
Duelund Silver Bypass Capacitor 0,01uF / 100VDC - 2% toleranceTechnical specifications (according to manufacturer): "Precision Speaker Capacitor; Pure Silver Foil; handmade in Denmark".Sound: In one word: amazing! I have used these 0,01uF pure silver foil capacitors as bypass capacitors in many different systems. In just about every case there was an improvement in overall coherency and realism of tone. With realism of tone I mean that acoustic instruments and vocalists seemed much more tangible, more intimate. The Duelund Silver Bypass Capacitor brings out a certain harmonic richness in overtones, for example with brass wind instruments the tone gets a sort of "glow" making them so much more realistic. Big-band music is bright and warm at the same time if you know what I mean, just like in real-life. And now for a cliché: the Duelund Silver Bypass Capacitor really does remove a curtain from the sound, creating more depth, insight and it generally does a very good job in cleaning things up. It does this without getting harsh nor adding artificial emphasis on any part of the spectrum, something that can happen with certain types of bypass caps.They even scared me once: my personal reference system uses a 1-inch beryllium compression driver connected to a tractrix horn that flares out to 29 inches. This "tweeter" has no resistors in the signal-path and is driven by a first order network, so only one capacitor in the direct signal-path. It works like an acoustic magnifying glass. I was fiddeling around as usual, tuning the value of this capacitor in steps of 0,10uF but the sound didn't quite seem to fall into place how I wanted it to. Then I decided to listen if the 0,01uF Duelund Silver Bypass Capacitor could help out here. Bingo! Makiko Hirabayashi's recording "Surely" (that I know very well) has some small bells that are used on several of the tracks. I thought I knew how they sounded but with the bypass capacitor in the network the bells were so realistic, it scared me I am so pleased with these universal bypass capacitors that I have decided to keep them in stock.Verdict: add about 2 points to whatever capacitor you are bypassing
I just ordered some Miflex KPCU from Sonic Craft, so they are back in stock. Last thing I need is some more capacitors, but oh, well...
While the Milfex are VG the Duelund is just better overall. Do not like the forward presentation. Does not sound linear to me. charles
My modded KEF Q100. Before with very cheap NOS Styroflex / Polystyrene 0.010 uF 600Vdc as bypass.And Würth 150 kHz 8 mm ferrite......
My latest and greatest version features OLED display and relay input switching. It can only be built in the cherry or walnut case. The special model has every option. (photo with large display at right)• 64 step remote Khozmo attenuator• relay input switching, one xlr input and 3 rca inputs• Duelund wiring• all film cap power supply• Polish oil caps on output• 4 CV181-T tubes included
By the way, I really don't have use for caps, inductors, resistors for my speakers anyway..., except one 0.47uf for high pass to my supertweeters.
"I'm guessing this test isn't much about duelund or Mundorf sio,...everyone knows they are amazing.Miflex is the new cap on the block and it's OK on its own...but the midrange is quite shy and top end slightly highlighted so it's not so well balanced to my personal opinion. But it has the best bass out of 3 caps!.Bypassing Miflex 0.47uf with Jupiter copper 0.047uf....fixes that problem.You will get great midrange of Jupiter copper !amazing 3d sound stage and bass to die for."
EFD RA31 capacitor condenseur - Google Search-> [PDF] https://exxelia.com/uploads/PDF/59bac6f55a3ad.pdf
