0 Members and 1 Guest are viewing this topic. Read 3411 times.
I would say go and try the Bluesound NODE 2i with your Qobuz 24/192 and compare it to the sound of your Sonos 16/44, if you can hear the difference change if not save your money. You and your family are already familiar and happy with the Sonos, so why change just because you can now run 24/192 if you can't hear the difference why bother?
I just went back to Sonos Connect after trying Roon / SOtM for a couple years. I was relieved to have the simplicty and reliability of Sonos back and to get rid of the continual minor technical problems. I don't care about hi rez files, as there aren't enough of them in the genres I like. For me, redbook resolution from Tidal HiFi is good enough. I added iFi Purifier between Sonos and DAC which makes a very noticeable improvement with my DAC because the Sonos jitter is rather high, but the reliability is most important to me. I'm sure BlueSound is just as good, I've only heard good things about if for a long time.
Bluesound has them on their website for $400 as well. I went the refurbished route, figuring why not save another $50.
Are you planning on paying the $25/mo it takes to get 24/192 via Qobuz? Every tier under that should sound the same through the Sonos. I don't know how much of the Qobuz library is stored in true 24/192.
I don't understand how that Paradigm device can apply ARC. Doesn't it need to implement filters using your preamp or receiver? I use it on my Anthem MRX 720 and it works great. The Play-Fi is on it also which does work well most of the time, but I've had some stuttering on the higher resolution stuff on Qobuz, I'm connected with ethernet to a very high speed router.
