CXC cd transport
0 Members and 1 Guest are viewing this topic. Read 4463 times.
Charles Calkins
CXC cd transport
« on: 2 Nov 2019, 09:01 pm »
      Hi Guys:
               I read so much about a cd transport and Dac combination that were better than a regular cd player
               I had to hear it for myself. I have a Cambridge Dac magic plus and I bought a Cambridge CXC transport.
               I compared it to a Marantz SA8004 cd player. The Cambridge Dac has dual Wolfson WM 8740 24-bit Dac's
               Don't know what Dac is in the Marantz.
               The Cambridge combination sounds very good. The Marantz sounds very good. I ran both of them at the same volume.
                I think the Cambridge has a wee bit better top end. That is the only difference in both players.
                The Cambridge combination is cheaper than the Marantz. Maybe by $300.00 cheaper.
                 That is all I have to say. I hope my findings helps someone looking for a new cd.
                                                      Cheers
                                                     Charlie
jtcf
Re: CXC cd transport
« Reply #1 on: 2 Nov 2019, 09:21 pm »
I use that transport myself.I'm very happy with it feeding my Tubadour lll dac.
displayname
« Reply #2 on: 2 Nov 2019, 09:41 pm »
Thanks for the simple and straight forward review. Looking forward to getting a CXC in house soon!
Charles Calkins
« Reply #3 on: 2 Nov 2019, 09:50 pm »
       Hi Guy:
             I figured if I already had a Cambridge dac I might as well buy their transport.
             Don't want to be switching dac's and transports all the time.
             Cambridge makes very good audio gear.
                                                    Cheers
                                                  Charlie
rollo
  • Rollo Audio Consulting -
« Reply #4 on: 2 Nov 2019, 11:40 pm »
  I am a big fan of dedicated transport feeding DAC. Especially with Ethernet. If one uses SPDIF go BNC connection. My 2 cents.
charles
bacobits1
« Reply #5 on: 3 Nov 2019, 12:43 pm »
I had super results using the CXC via a Lifatec Optical cable too. It killed my at the time Marantz SA14 LE (2k) as a transport.
Since I play CeeDee's Im thinking about buying another and stashing it.
