ECC99 and ECC82 Equivalent Tube Codes?
0 Members and 1 Guest are viewing this topic. Read 8695 times.
fado
« on: 24 Oct 2019, 06:00 pm »
I will be getting the Lampizator Amber 3 DAC which uses "a ECC99 super tube as input amplifier, in a zero feedback, single ended triode mode, as well as ECC82 as low impedance output buffer." I don't know the exact tubes Lampizator supplies with this DAC but there is always the temptation to find something better - either new or NOS but online I find the following listed equivalencies:  ECC99 = 6N6P ~ E182CC Russian Double Triode Tube, 6N6P / 6Н6П, 6N30P-DR. Do these codes seem correct?
Rusty Jefferson
Re: ECC99 and ECC82 Equivalent Tube Codes?
« Reply #1 on: 24 Oct 2019, 08:31 pm »
I believe the 12bh7 is the equivalent for the ecc99, but check with a pro.
Don't get too caught up with that tube however, but rather the Cathode follower/output tube, the 12au7.  That makes a tremendous difference with the Amber 3 and are worth rolling different varieties after you have it running a few weeks to break it in.
Here's a chart from the Tube World website (no affiliation) I've found to be quite accurate.
Rusty Jefferson
« Reply #2 on: 24 Oct 2019, 09:12 pm »
I believe the 12bh7 is the equivalent for the ecc99, but check with a pro....
And/or the Lampizator guys Fred and Rob.  I just realized this thread isn't in the Lampizator circle.
JakeJ
« Reply #3 on: 24 Oct 2019, 09:39 pm »
I did a casual search and came up with no subs for the ECC99.
JakeJ
« Reply #4 on: 24 Oct 2019, 10:05 pm »
I take it back.  I just found this.
