0 Members and 1 Guest are viewing this topic. Read 8901 times.
I have it's bigger brother hooked up to some Omega SAMs. Put it this way. I play a lot less with my other equipment. Garry is a little bit hard to get ahold of, but his products are excellent. Far better than you would think. My only quibble is that his power estimate may be a little off, but that's by ear. I usually run tube or SS monos. Haven't felt the need to unplug his stuff since I got it. I also play with lower volume. People have griped in the past about quality control. The MP501 I got was extremely well packed. As good as anything from other brands I've had in my house.YMMV
^ won't argue this but.... what is your musical preference? I've heard them all, minus the 8" driver, and they all sound great! specially with tubes!like everything else there is tradeoff between the different drivers/speakers. in the end you can't lose with Louis (:
I haven't heard the Super 7 MK II's so can't comment on them but I can comment on the SAM's and the High Output SAM's. Both are exceptional with tubes, I was pushing SAM's with a Decware 2 watt SE84UFO2 amp and the combination was awesome. I have a fairly large listening area (22'X24') and was surprised at how that combination filled the space, I didn't want for higher dB levels but for a little more bass. I spoke to Louis and he suggested either pairing them with a couple Deep Hemp subwoofers or upgrade to the High Output SAM's. Having messed with trying to incorporate subs before and knowing the wife would ask "what are those and why do you need them?" I opted for the HO version and haven't looked back. I'm not sure what Louis' current policy is but he offered to take my SAM's back in a trade to offset the cost differential of buying the HO SAM's!!!! I now swap between the 2 watt Decware amp and a 10 watt LTA ZOTL10 in my system and they both work famously!!! Couldn't be happier. I'm lucky as I live in CT and was able to visit Louis at his shop on more than one occasion before I made my upgrade decision. If at all possible, make a visit, I am sure he would let you listen to whatever speakers he has on hand in his shop with your own amp. If not then trust whichever model you opt for will sound amazing with your Musical Paradise amp because they will. Long story short, LOL, I would kick in the extra $500 and get the CAM's. Also seek out some of Canada Rob's posts here, he can compare the 7's to the CAM's better than most.
