Feet for NX-Otica and subs
0 Members and 1 Guest are viewing this topic. Read 968 times.
Jaytor
« on: 22 Oct 2019, 12:04 am »
I've got a set of NX-Otica kits on order and plan on building the triple 12" OB subs as well. They will be in a room with travertine tile floors over slab. What have you all used for feet under the bases when placing them on hard floors? Bases directly on the floor, felt pads, spikes with cups, Herbie's dots, Herbie's Gilders, IsoAcoustics Gaia isolators?
If you've used something more exotic, like Herbie's Gliders or the Gaias, did you try them without these beforehand? If so, what differences did you find before and after?
Jay
Endo2112
  • Particularist
Re: Feet for NX-Otica and subs
« Reply #1 on: 22 Oct 2019, 02:46 am »
I love my Iso-Gaia 1's, i've used them on tile slats, and now on hardwood, i'm sure that you could probably use the 11's with the less weight of the Ottica's and save a few dollars.
Don
