KWA 150se going into thermal shutdown
0 Members and 1 Guest are viewing this topic. Read 2746 times.
HowardC
« on: 11 Oct 2019, 06:29 am »
Hi all,
My ModWright KWA 150se goes into thermal shutdown after an hour or so in the high bias mode.  The amp is ventilated properly and is on spikes with pads on a hardwood floor.  It does not shut down When continuously operated in the low bias mode.
Any Help would be greatly appreciated.
rklein
  • My finest audio piece ever!!
Re: KWA 150se going into thermal shutdown
« Reply #1 on: 11 Oct 2019, 03:08 pm »
The amp will probably need to go back to Modwright to fix the problem.  A friend let me borrow his 150SE and it also was shutting down on high bias setting.  I believe that the amp got sent back to Dan who then fixed this problem.
Regards
Randy
RDavidson
« Reply #2 on: 11 Oct 2019, 04:13 pm »
From my Ewok level of technical knowledge, it's probably a thermistor that is overly sensitive or out of spec. Should be an easy fix if that's the case.
billc
« Reply #3 on: 17 Oct 2019, 04:55 am »
Both my 150SE's were running very warm/hot.  I even put a quiet computer fan near one because I was worried about thermal shutdown, or reduced equipment life.
But, in talking the issue over with Dan, he indicated that he now biases the amp at a lower level.
He brought the high bias setting down on both amps, with absolutely no discernable effect on sound quality.
And both run much cooler now.
I strongly recommend you talk with him.  His product service is fantastic!
Biil C
Phil A
« Reply #4 on: 17 Oct 2019, 01:45 pm »
Hi all,
What speakers are you using?
Phil A
« Reply #5 on: 17 Oct 2019, 01:45 pm »
Hi all,
PS - Welcome to the forum!
fado
« Reply #6 on: 17 Oct 2019, 04:20 pm »
How old are your 150SE's?
