Audio/Video Gear and Systems
The Musician's Circle
eclein
Piano tuning
Piano tuning
S Clark
a riot is the language of the unheard- Dr. King
Piano tuning
10 Oct 2019, 03:19 am »
Has anyone here tuned a piano? I got most of mine done, when I started breaking the low single wire strings.
Advice?
Volunteer
Audio Transformers Consulting
Re: Piano tuning
10 Oct 2019, 03:41 am »
Tuning in 432Hz
S Clark
Re: Piano tuning
Reply #2 on:
10 Oct 2019, 03:52 am »
I know I can tune a partial pitch down, but I like to play with recordings, so a 440 tuning is what I'll stay with.... unless I can't find another solution from someone with tuning experience.
EkW
Re: Piano tuning
Reply #3 on:
10 Oct 2019, 04:59 am »
I've done a little tuning of my piano but usually just a touch up between real tunings. You might try searching through the technical discussion section in the pianoworld forum.
The book 'Pianos Inside Out' suggests checking for correct wire gauge first, then see if the V bar is grooved. If so, lubricate. If strings still break restring whole section or even the whole piano. Maybe the strngs are just old and weak? Also, it is usually ok to have the bass strings a bit flat. Our sensitivity to tuning is weaker in the lowest octave.
Tone Depth
Music Lover
Re: Piano tuning
Reply #4 on:
10 Oct 2019, 05:28 am »
Spend the money on a registered piano technician and get the job done correctly.
S Clark
Re: Piano tuning
Reply #5 on:
10 Oct 2019, 05:49 am »
Yeah, I tried that first, but the guy I had used for years died, and there aren't that many other options nearby.
RoadTripper
Re: Piano tuning
Reply #6 on:
10 Oct 2019, 01:42 pm »
I was a professional piano tuner, technician, rebuilder for many years until I switched careers. Tuned thousands of pianos. What kind of advice are you asking about? How to replace a bass string?
S Clark
Re: Piano tuning
Reply #7 on:
10 Oct 2019, 03:27 pm »
Let's start with why did I break two strings? The first one you could chalk up to carelessness, but the second one I was approaching with great patience. Should you bring it up to a point and let it rest? Is a 440 tuning inadvisable for a piano that's been for 10+ years?
Although, at this point, I'll find a tuner, even if I have to pay a travel fee.
RoadTripper
Re: Piano tuning
Reply #8 on:
11 Oct 2019, 02:15 pm »
Sorry about the late reply. My laptop died. I would say it is more about the age of the piano. How old is it? Ten years without being tuned isn’t ridiculous. The tuner you hire is likely to break a few if your second (careful) break was at pitch. Bass string replacement isn’t cheap these days. And then there is the added cost of bringing those new bass strings back up to pitch after they sag and you can’t stand it anymore. Although you could probably touch those up yourself.
S Clark
Re: Piano tuning
Reply #9 on:
11 Oct 2019, 03:05 pm »
It's a little Chickering spinet, built about 1945. So, by piano standards, it's not especially old. It's not anything great, but it's tone is better than it should be. I played for years on decent size grands, but I don't play enough now to justify the space.
There is a place in Tennessee that offers bass strings at about $20 each, although I saw a you tube showing that you can splice a string that broke at the pin. Ever done that?
RoadTripper
Re: Piano tuning
Reply #10 on:
11 Oct 2019, 04:42 pm »
Oh yeah. That bass string splice is a lot of fun. Bring band-aids. That wire is really stiff, but it works. To pull off the splice, you will need new wire and that will be heavy gauge, to match, more or less. Using the existing wire that is still wrapped around the tuning pin (and unwinding it some) will make that job even more ridiculous.
As for a 1945 Chickering, it's mostly about how much rust/corrosion has occurred to weaken the string. It's also possible that the wire has "fused" to the metal over which the string lies. You could loosen the wire enough to free each one up if you intend to keep tuning (or as just a test). But my guess is it's just a matter of the wire has gotten too compromised to handle the tension.
Tone Depth
Music Lover
Re: Piano tuning
Reply #11 on:
16 Apr 2022, 05:33 am »
In our family's shared vacation home we had a baby grand (1905 Steinway Model O). It would occasionally get tuned for informal concerts, which led to a few broken strings. We would spend a week there every Summer. I decided I would oversee getting the piano in better shape. I engaged a Piano tuner whom assessed the condition of the piano and found it was noticeably flat. Not wanting anymore broken strings, I started an annual tuning incorporating a partial pitch raise. Over the next five years, we slowly got it up to concert pitch without breaking anymore strings. It took patience, but the result was worth it. For me, it was inspiring playing a fine instrument in great shape in a beautiful mountainside setting. Unfortunately, last summer we had to sell out to a cousin, there were too many family members involved that could not get along maintaining the property.
Digi-G
Re: Piano tuning
Reply #12 on:
18 Apr 2022, 06:46 pm »
I've got a baby grand (Sohmer) that I seriously considered tuning myself, in the midst of Covid. My normal tuner guy is elderly and wasn't going around other people.
I'm kinda glad I didn't do it. I surely would have broken something. I'll call my tuner guy Jack, cause that's his name. When Jack finally did Get Back with me and came to tune it, he said he was glad that I didn't do it. And at $100 I don't think it was really about the money. I have the impression he looked at it more like an art and not a technical exercise. He used terms, like shading (?), that I hadn't heard in that context before. Definitely gave me the impression there's more to it than making each string a certain pitch. He did part of it with a fancy tuner and some parts by ear. Maybe he was blowing smoke up my ashtray, I dunno.
He's a cool guy though, and I enjoy seeing him every once in a while. He toured the US back in the 1960s with a band that I never heard of, but rubbed elbows with plenty of people I have heard of. Last time here he played me a couple of new, original songs he had recently written. Very impressive.
Digi-G
Re: Piano tuning
Reply #13 on:
18 Apr 2022, 06:47 pm »
<Delete>
Volunteer
Re: Piano tuning
Reply #14 on:
18 Apr 2022, 11:42 pm »
A complete tuning job also should include the intonation of the strings what takes time.
eclein
Piano tuning
