0 Members and 1 Guest are viewing this topic. Read 6978 times.
Scott, It's no wonder you felt ill! Have you ever read anything of Vladimir Gavreau's research on weaponry?http://www.borderlands.com/archives/arch/gavreaus.htm
The main resonant frequency of these pipes occurred in the "range of death", found to lie between three and seven cycles per second. These sounds could not be humanly heard, a distinct advantage for a defense system. The effects were felt however. The symptoms come on rapidly and unexpectedly, though the pipes were operating for a few seconds. Their pressure waves impacted against the entire body in a terrible and inescapable grip. The grip was a pressure which came in on one from all sides simultaneously, an envelope of death.
Tolerances from 40 to 100 cycles per second have been recorded by military examiners. The results are sobering ones. As infrasonic pitches decrease, the deadly symptoms increase. Altered cardiac rhythms, with pulse rates rising to 40 percent of their rest values, are the precursors to other pre-lethal states. Mild nausea, giddiness, skin flushing, and body tingling occur at 100 cycles per second. Vertigo, anxiety, extreme fatigue, throat pressure, and respiratory dysfunction follow. Coughing, severe sternal pressure, choking, excessive salivation, extreme swallowing pains, inability to breathe, headache, and abdominal pain occur between 60 and 73 cycles per second. Post exposure fatigue is marked. Certain subjects continued to cough for half an hour, while many continued the skin-flush manifestation for up to four hours.
..... but I don't think I could take the rocking chair!
If a properly tuned Shiva can play reasonably flat down to 12 hz, that would be plenty for me. Not that I couldn't consider another driver, but the Shiva & Tempest are affordable and they're known quantities.
BTW, where/how did you get the 1" thick plastic material you made the baffle out of?
My partition supplier of choice is Global toilet partitions (they have a website somewhere)
