I originally passed this upgrade to my chagrin. Those are an impressive set of instructions. Where do you get the 10" passive radiators. I have the active speakers in my set. I have OXOs rather than internal crossovers. I assume the same modifications apply.
Just discovered that all four of the 6.5" downward firing passive radiators in my RM-30 speakers are shot. The cloth edging is torn. Has anyone had these repaired or repaired them their selves. Any other suggestions.Thanks,
How did you discover this? Was there some sonic degradation or did you just have a look?I have RM30Ms from 2006 and can't see or feel any degradation to any of the drivers.
I was experimenting with adding/subtracting mortite. A one point while they were playing I put my hand in to check on how much mortite I had on one of the passives and felt all kinds of air moving. From there I figured out that the passives edges had fallen apart. The interesting thing was after a recent source upgrade I still was not getting the sound I wanted. I removed a lot of mortite and wow, what an improvement. I hadn't touched the dampening for years prior to that. Not sure what if any relationship there is. I have blocked the bottom ports on the speakers as a simple way to cancel the passives, or lack of passives. The sound is still great. Though last night during a very loud blast of bass during a movie one of the blocks literally came flying off the speaker. That was a fitting end to a scheme showing an exploding planet.Still trying to decide whether to do the upgrade or replace/repair the passives. Either way involves some serious work given the weight and size of the speakers.
Repairing them would mean removing the base and dismounting the passives with a screwdriver or phillips attachment to a ratchet wrench (safer). It's not that big a deal. Then sending them to a speaker repair expert. Yes, the Series II upgrade is more involved but improves the sound. See if you can still get the 10" passive radiators and mega woofers. If you can't, just get the surrounds replaced on the down-firing passives.
I understand the 10" passive radiator but what are the mega woofers?
