0 Members and 2 Guests are viewing this topic. Read 29695 times.
Ward,That turned out nice Thanks for sharing. I'm guessing those RTEs fit right under the board. Any time on it yet?Jeff
The RTEs are fine. I just used some aluminum standoffs a couple mils taller and found a case that would allow the raised PCB. Only time has been for warm up, bias set and a couple of songs. My first impression is good. It is what I would expect from a triode. Not edgy or too bright, very clean and good detail.
Once again, a huge thank you to Jeff for helping me take this preamplifier build to the next level. Nelson Pass designed this board around the Korg Nutube 6P1 dual triode. It runs on 29vdc. The original kit spec'd some cheap parts to fit a budget build. I wanted something better. This thing hits way above its weight class.
Where is the tube or tubes?
Where did you get the plans and board?
