Another interesting technology.....5.1 room eq
0 Members and 1 Guest are viewing this topic. Read 1658 times.
ted_b
« on: 5 Feb 2005, 08:01 pm »
This one has Tomlinson Holman involved.  I've an email with a bunch of questions into them.  If I find out more I'll report back.  Anyone heard this?
http://www.audioholics.com/techtips/specsformats/AudysseyMultEQ3.php
Ted
Edit:
Some more info... Uses FIR filters.  The discussion about clustering seats using fuzzy logic, and giving the audiophile seat (sweetspot) the best sound, is quite interesting.
http://www.audioholics.com/techtips/specsformats/AudysseyMultEQ2.php
jgubman
« Reply #1 on: 5 Feb 2005, 08:49 pm »
More to read (a lot more...) here
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=442704
Has a lot of info on the multiEq from Chris Kyriakakis, Audyssey's CTO.
kaxixi
    • http://home.uchicago.edu/~eyoeli
Have you heard it in a living room?
« Reply #2 on: 6 Feb 2005, 10:09 pm »
Has anyone listened to a receiver with this technology (Onkyo and Denon both offer them--its called `Auto Setup' I believe) at home in a living room?  It sounds very promising (people are saying great things about two channel FIR equalization).  A much cheaper alternative to treating your living room (especially when you take the divorce into account).
ted_b
« Reply #3 on: 7 Feb 2005, 05:02 am »
Although all of these better room eq technologies will go on record as saying that they will perform MUCH better in a well-treated room.  As Tom Holman says, there is no electronic fix for first reflections.
Ted
geofstro
    • Sound Galleries: High-End Audio in Monaco
« Reply #4 on: 7 Feb 2005, 05:58 pm »
I also read that. Apparently those first reflections can be handily tamed with some attractive potted plants though, which usually have a high WAF. Add a nice carpet or two and you're there.
DRC works well in conjunction with these traditional room treatments, as I understand it.
geoff
kaxixi
how 'bout cats?
« Reply #5 on: 9 Feb 2005, 01:56 am »
I tried the plants, but the cats ate them.  :(   I tried the cats, but they ran away.   :wink:  Considered drapes, but the cats came back.   :?
geofstro
« Reply #6 on: 9 Feb 2005, 08:07 am »
My cat, so far, is surprisingly well behaved. I have him trained to avoid the speakers and the rest of the system by a wide margin (he describes a large cirlce to avoid them). At first I was worried he would think the speakers are trees.
He would love a nice expensive rug to sharpen his claws on though. I'm hoping he'll go for the potted plants instead.
geoff
kaxixi
I was smart...
« Reply #7 on: 10 Feb 2005, 08:49 pm »
... I picked up a rug for free.  You can't see the stains once its shredded (and shredding works wonders in the 5-10K range).
