USB music data in, USB out to DAC
0 Members and 1 Guest are viewing this topic. Read 2140 times.
Mike B.
« on: 17 Sep 2019, 05:08 pm »
I have my music stored on a Fathom USB drive going into a dedicated Intel I7 NUC. Signal comes out of NUC to DAC via USB. I recently saw a thread here where that was not advised by a poster. Why is this a problem if at all?
mcgsxr
Re: USB music data in, USB out to DAC
« Reply #1 on: 17 Sep 2019, 07:51 pm »
I'll be interested in the theory.
I hang a 5TB drive off my dedicated netbook - though the music is then fed ethernet to a player and then via optical to the DAC.
Mike B.
« Reply #2 on: 17 Sep 2019, 08:31 pm »
I tied to locate the thread about it with no success. I think it was Steve N. who stated it.
Vincent Kars
  • The Well Tempered Computer
« Reply #3 on: 30 Sep 2019, 01:23 pm »
It reminds me a bit of discussions on https://www.audioasylum.com/cgi/etv.mpl?forum=pcaudio in the period 2010-2015.
Some even suggested one should use different protocols e.g. USB for data and  firewire for audio.
All of this to improve the sound quality.
If you want to experiment a little, you might try having the data and the DAC on different hubs.
Or even better, the DAC as the single user of a hub.
http://www.thewelltemperedcomputer.com/SW/Windows/Win7/USBDAC.htm
If you do have a DAC with sufficient isolation at the USB receiver, I don’t expect any difference.
However, some USB ports might be more prone to CRC errors, in that specific case, changing ports might help.
http://www.thewelltemperedcomputer.com/HW/USB_Trouble.htm
Mike B.
« Reply #4 on: 30 Sep 2019, 05:52 pm »
If I remember correctly, the person was recommending putting the data drives on a network and accessing them by ethernet. I tied it and didn't find any sonic performance difference. It did mess with my remote control of Jriver using a tablet.
