What's Next?
0 Members and 1 Guest are viewing this topic. Read 4471 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
What's Next?
« on: 7 Sep 2019, 04:21 pm »
Five projects are in the works, all using the Accuton C51 ceramic dome midrange and RAAL 70-10D-AM ribbon tweeter. Stay tuned!
uncola
Re: What's Next?
« Reply #1 on: 8 Sep 2019, 01:23 pm »
exciting!  I have a jeff bagby kairos full kit in a box but I realized I'm never going to have the time to learn woodworking.  so I look forward to your new designs :)
ever think about experimenting with non conventional designs like omnidirectional full range  or open baffle mtm with sealed box bass woofers below?  I was looking at the ohm walsh recently, pretty interesting design.. or what about something using a seos horn?
nc42acc
Re: What's Next?
« Reply #2 on: 8 Sep 2019, 02:18 pm »
Call me interested Rick. Any plans for a TMWW configuration using these drivers?
uncola
Re: What's Next?
« Reply #3 on: 8 Sep 2019, 02:42 pm »
he had a design like that which was basically a tmww version of the tempesta called the estremo.  would be cool to see an update to it
AvFan
Re: What's Next?
« Reply #4 on: 8 Sep 2019, 08:05 pm »
Good combo.  As noted, similar to the Tempesta but also the Ottavo.
rollo
  • Rollo Audio Consulting -
Re: What's Next?
« Reply #5 on: 9 Sep 2019, 03:07 pm »
   Nice choice Rick.  Good luck.
charles
simoon
Re: What's Next?
« Reply #6 on: 9 Sep 2019, 04:45 pm »
2 of the best drivers on the market, for sure.
I can't imagine these sounding anything but great.
Not trying to hijack the thread, but I'd be willing to purchase those Kairos kits from you!
I'll PM you.
Rick Craig
  • Selah Audio
Re: What's Next?
« Reply #7 on: 9 Sep 2019, 05:17 pm »
Here are some of the less conventional designs that I've done. Personally I don't care for many horns but there are some good drivers - just very expensive. Dipoles / open baffle are executed best with a DSP crossover.
Rick Craig
  • Selah Audio
Re: What's Next?
« Reply #8 on: 9 Sep 2019, 06:51 pm »
Yes, there will be a new version of the Estremo.
Rick Craig
  • Selah Audio
Re: What's Next?
« Reply #9 on: 13 Sep 2019, 07:27 pm »
Up next for final assembly and test  - matching L/R/C and surrounds. After that comes the "Harbinger".
NaDs
Re: What's Next?
« Reply #10 on: 14 Sep 2019, 01:18 am »
Looking good! What veneer is that? Also, is that the 9.5 inch satori?
Rick Craig
  • Selah Audio
Re: What's Next?
« Reply #11 on: 14 Sep 2019, 03:57 pm »
It's Figured Eucalyptus with a dye added to the finish.  9.5" Satori woofer, Accuton Cell dome midrange, and RAAL 70-10D-AM tweeter.
