0 Members and 1 Guest are viewing this topic. Read 2747 times.
Okay I'm trying to set up a turntable so that I can transfer numerous Lp's to cd. I have two Technic TT both with broken belts, one is basic, the other has some kind of gears and strobe light. The basic one has the cartridge the better one has no cartridge. And a Dual, with a cheap cartridge, but a good belt. I didn't want to use the Dual because the last time I recall using it I was getting a hum from what I believe was where the tonearm and cartridge meet.So the question is are all belts for turntables the same size.Next I have no phono in on pre-amp, I tried hooking TT through Tape and Aux, but sound is weak, at least I know I'm getting sound, but the speed was slow, so is the belt slipping?The question, if I connect the TT phono outs to a Roxio Usb adaptor and then to Usb In on external dac, do you think I will get sound?
Where are you located?
But I still need a belt for Technics TT.
We'll try to help you with anything you want to do, but why transfer to CD when you could put it all on one hard drive?
