2 KEF B110 drivers - free to good home
mitch stl
« on: 26 Aug 2019, 08:38 pm »
St. Louis area only. Getting rid of some old stuff and disassembled some home brewed LS3/5a clones that I built back in 1979. The drivers have been removed from the cabinets (discarded). They were working the last time i used them and a quick free-air check this afternoon indicated they still work, though did not check for bass & volume.
The main features are the two KEF B110 drivers. Note these are the ones used in the earlier 15 ohm model of the LS3/5a. Included are the original mounting screws. On one driver you'll need to fuss a bit with the electric connections which came loose from the frame. Also included are two generic soft-dome tweeters, one with a dented cone. The original T27s are long gone.
Contact me on the message board if you're interested.
OzarkTom
Re: 2 KEF B110 drivers - free to good home
« Reply #1 on: 27 Aug 2019, 06:16 am »
 I have taken a vacuum cleaner before and sucked our dented tweeters.
