1st Review of C•100S in The Absolute Sound
0 Members and 1 Guest are viewing this topic. Read 5786 times.
CIAudio
« on: 21 Aug 2019, 02:57 pm »
The first review of our new C•100S 100 watt per channel stereo amplifier is in the September issue of The Absolute Sound.
C•100S ($1495) held its own vs their reference, the Pass Labs 150.8 ($6750).
"if you want an amplifier that has "personality" you should look elsewhere. But if you need a harmonically neutral power amplifier that you can attach to a wide variety of speakers, the C•100S would be an excellent choice.
And priced at $1500, the C•100S ranks as a "best buy" in my world".
-Steven Stone-
« Last Edit: 21 Jan 2020, 01:36 am by CIAudio »
rollo
  • Rollo Audio Consulting -
Re: 1st Review of C•100S in The Absolute Sound
« Reply #1 on: 21 Aug 2019, 07:10 pm »
  Stepping on up, good for you. Nice Amp BTW.
charles
« Reply #2 on: 21 Aug 2019, 07:30 pm »
Is it available with XLR inputs?  And is it a natively balanced design?
Are the stated physical dimensions, under additional information, correct (18 x 12 x 8 inches) or are the physical dimensions stated under specifications as 8.5 x 2.75 x 10 inches right?
CIAudio
« Reply #3 on: 21 Aug 2019, 07:37 pm »
The design is balanced internally for low noise, but single-ended input only.
The smaller dimensions are the actual product size... the dimensions in the "additional information" are shipping carton size.
CIAudio
