Rec's for 5687 rolling
0 Members and 1 Guest are viewing this topic. Read 12155 times.
Rusty Jefferson
Re: Rec's for 5687 rolling
« Reply #20 on: 27 Sep 2019, 06:12 pm »
Since you can hear the noise through your speakers when you tap on the knob, that is a microphonics issue. They may still be fine for another application, but not in a high gain preamp.  The feedback is likely a separate issue.
I clicked on the link in the video FRM posted and it took me to Brent's website.  Perhaps he didn't test these tubes as well as he could have. I'd exchange them explaining the issue.  You'll likely get a better pair if they're available, or a refund if not.
It can be hard to get a hold of Andy sometimes. One man shop.  Sometimes he may not have what you need on hand but he has sources and is always buying tubes. I let him know what I need and he usually calls back to say he's found/bought some.
Once you hear the tubes that bring the magic, it can be hard to even turn on your stereo until you have them. :D
Yomaha
« Reply #21 on: 30 Sep 2019, 08:49 pm »
As soon as I had received the Tung-Sol's and I noticed the issue, I had notified Brent.  he had said it should clear up with time, but it hasn't.  I explained that to him and he offered to exchange the tubes for a different set, no hassle at all.  I put them in the mail to him today
« Reply #22 on: 30 Sep 2019, 09:05 pm »
Hm, keep us posted.
eichlerera1
« Reply #23 on: 1 Oct 2019, 03:57 am »
Micro phonics will NOT clear up with time.
Get your money back and deal with Andy.....
« Reply #24 on: 2 Oct 2019, 01:17 am »
With the extreme shocks and vibrations common in transportation the clearances between the elements tend to increase and the microphony as well.
eichlerera1
« Reply #25 on: 2 Oct 2019, 04:22 am »
Not if the tubes are packed correctly...
« Reply #26 on: 2 Oct 2019, 04:30 am »
shakey
« Reply #27 on: 11 Nov 2019, 09:21 pm »
7044
