External DAC with Nuprime IDA-8
0 Members and 1 Guest are viewing this topic. Read 2365 times.
SRO
« on: 12 Aug 2019, 07:48 am »
Can you use an external DAC connected through the IDA-8 analogue connection without changing the signal from that input, or is the input from the external DAC filtered through the IDA-8 DAC changing the original input, as the analogue inputs are digitized I believe?
rustydoglim
Re: External DAC with Nuprime IDA-8
« Reply #1 on: 13 Aug 2019, 04:08 pm »
The analog input on IDA-8 is digitised so you don't want to use the analog output for DAC again.
SRO
« Reply #2 on: 14 Aug 2019, 11:27 am »
Thanks.  Just to confirm, if I understand what you're saying it's best to use the internal DAC of the IDA-8 because even the analogue signal is filtered through the IDA-8 DAC.  Correct?
JackD
« Reply #3 on: 15 Aug 2019, 04:14 am »
Yes.
