Windows 10 Paint Select Tool Problem
« on: 8 Aug 2019, 03:10 am »
My Windows 10 MS Paint (not Paint 3D) are unable to drag small areas, the select tool are not operating as due, its no more possible to select and drag small areas in JPG, PNG, GIF or BMP images, only large areas selected are allow to move.
My built is 1903 OS 18362.267
It was working properly a few weeks ago.
Iam not happy as I use Paint everyday.
« Last Edit: 9 Aug 2019, 10:22 pm by FullRangeMan »
Re: Windows 10 Paint Select Tool Problem
« Reply #1 on: 8 Aug 2019, 03:42 am »
Small areas are unable to move:
Large areas are allowed to move:
Phil A
« Reply #2 on: 8 Aug 2019, 12:50 pm »
Does it happen when you select cut?  How about if you select the area and hit 'Ctrl' and 'X' and then move it to another area and hit 'Paste.'
« Reply #3 on: 8 Aug 2019, 11:58 pm »
It happen when I use Rectangular Selection or Free Form Selection.
I do what you suggest and the copied area appear as usual in the top left area of the image but it was unable to move to the suited area as happened before.
« Last Edit: 9 Aug 2019, 07:27 am by FullRangeMan »
« Reply #4 on: 9 Aug 2019, 02:59 am »
This lined square is the proper tool to select and drag but it was supressed by Microsoft a few time ago:
« Reply #6 on: 9 Aug 2019, 10:24 pm »
Thanks Phil, my Paint also is no more on the Settings/app programs list and also gone from the Start menu :scratch:
bacobits1
« Reply #7 on: 9 Aug 2019, 11:27 pm »
Try running, command prompt
      --------->              sfc /scannow
See if that will fix some files??
Go back to a previous version of Windows.
I have found these BS " cumulative updates" screw things up.
I stopped all updates except for Win antivirus updates.
I just restored my system. Getting slow over time.
It gives you the choice to save your files and programs, with a listing off what you would have to reinstall.
Or clean install of Win 10.
« Reply #8 on: 9 Aug 2019, 11:42 pm »
I has run sfc /scannow and nothing happen :scratch:
Wait it need  admin status.
bacobits1
« Reply #9 on: 9 Aug 2019, 11:47 pm »
So much for the system file scan.
You wonder how this stuff breaks in the first place.
It would be easier if it was a separate program,, but it's built in.
« Reply #10 on: 10 Aug 2019, 12:23 am »
Unfortunately there is some files corrupted, buy I cant access the log:
PS C:\WINDOWS\system32> windir\logs\cbs\cbs.logwindir\logs\cbs\cbs.log
windir\logs\cbs\cbs.logwindir\logs\cbs\cbs.log : The module 'windir' could not be loaded. For more information, run
'Import-Module windir'.
At line:1 char:1
+ windir\logs\cbs\cbs.logwindir\logs\cbs\cbs.log
    + CategoryInfo          : ObjectNotFound: (windir\logs\cbs...ogs\cbs\cbs.log:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CouldNotAutoLoadModule
bacobits1
« Reply #11 on: 10 Aug 2019, 12:28 am »
Beyond me....
« Reply #12 on: 10 Aug 2019, 12:48 am »
Thanks bro much appreciated.
EDIT: found the log at: C:\Windows\Logs\CBS\CBS.log
This is a big file though.
« Last Edit: 10 Aug 2019, 02:05 am by FullRangeMan »
« Reply #13 on: 10 Aug 2019, 03:05 am »
Seems the corrupted files are:
MSFT_MpComputerStatus.cdxml' do not match. Expected:
MSFT_MpComputerStatus.cdxml of Windows-Defender-Management-Powershell,
MSFT_MpThreat.cdxml' of Windows-Defender-Management-Powershell,
MSFT_MpThreatCatalog.cdxml' do not match
MSFT_MpThreatCatalog.cdxml' of Windows-Defender-Management-Powershell,
MSFT_MpThreatDetection.cdxml' of Windows-Defender-Management-Powershell,
MSFT_MpPreference.cdxml' do not match.  Expected: {l:32 ml:33
MSFT_MpPreference.cdxml' of Windows-Defender-Management-Powershell, in the store, hash mismatch
MSFT_MpScan.cdxml' of Windows-Defender-Management-Powershell, in the store, hash mismatch
MSFT_MpWDOScan.cdxml' do not match.
MSFT_MpSignature.cdxml' do not match.
Defender.psd1' of Windows-Defender-Management-Powershell, version in the store, hash mismatch
Hashes for file member [l:26]'MSFT_MpThreatCatalog.cdxml' do not match.
And other files always similar to these  :scratch:
bacobits1
« Reply #14 on: 10 Aug 2019, 01:17 pm »
WGH
« Reply #15 on: 10 Aug 2019, 04:24 pm »
Where did you get Paint? All I could find is Paint3D which has both 2D and 3D. My Windows 10 only has Paint3D.
Usually the best and only solution is to uninstall the program using either using Windows or CCleaner and then re-install a current version.
Here is how:
https://www.intowindows.com/uninstall-or-reinstall-paint-3d-app-in-windows-10/
srb
« Reply #16 on: 10 Aug 2019, 05:00 pm »
Paint (old 2D) was included with Windows 10 and remains installed after updating to Creators Edition.  You can find it under Windows Accessories or click the Start button, type "paint" and it should bring up both Paint and Paint 3D.
Paint no longer exists in new OEM or Retail releases as Microsoft feels the 2D functionality is available in Paint 3D.  For a while it was available as an app to download at the Microsoft Store, but for whatever reason can't be found there now.
There is no uninstall routine for it, and like many other Windows accessories and small apps, are just part of the OS.
I was thinking that if Paint was still available at the MS Store, maybe it could be downloaded and installed to overwrite/repair the existing one, but maybe it would have generated an 'already installed' error, who knows?  For now it's a moot point.
WGH
« Reply #17 on: 10 Aug 2019, 11:35 pm »
MS Paint with extra features, recreated in Javascript.
https://jspaint.app/
Read the ABOUT page:
https://github.com/1j01/jspaint#readme
"Ah yes, good old paint. Not the one with the ribbons or the new skeuomorphic one with the interface that can take up nearly half the screen. And sorry, not the even newer Paint 3D.
Windows 95, 98, and XP were the golden years of paint. You had a tool box and a color box, a foreground color and a background color, and that was all you needed.
"Things were simple.
But we want to undo more than three actions. We want to edit transparent images. We can't just keep using the old paint."
"So that's why I'm making JS Paint. I want to bring good old paint into the modern era.
