Thanks. I hooked a HD to my Node 2i. It works, but not as well as I'd like.
I have a Node 2i and since it won't access my iTunes library over my network (because it's on an external drive and not the iMac's own local drive), I've been thinking of copying some or all of it to a second external drive that I would plug directly into the Node via USB. I'd be very interested in hearing about the issues you've had with your setup.
I’m not familiar with the Bluesound architecture, but many devices share the USB buss with ethernet or wifi which degrades speed and performance significantly.DMC has very snappy performance and scans local music drives quickly.
It took 10-15 minutes for the node 2i to "scan" my HD with a little over 1tb of files.
Hey Dusty, do you recommend leaving the DMC-1 powered on at all times?
Great. Yes, already saved it to home screen.
Sweet!
