New Copper Caps and pricing
0 Members and 1 Guest are viewing this topic. Read 15955 times.
Danny Richie
« on: 17 Jul 2019, 10:15 pm »
Okay guys these are the new caps that I will be carrying. They are a pure Copper foil and wax paper film design. These are 100 volt rated caps.
I will be offering introductory discount prices of 25% off when two or more caps are ordered.
Here are the sizes, retail prices, and introductory discount price.
5.0uF retail $275 each, and discounted $206.25
6.0uF retail $315 each, and discounted $236.25
6.8uF retail $320 each, and discounted $240.00
8.0uF retail $325 each, and discounted $243.75
9.0uF retail $345 each, and discounted $258.75
10uF retail $350 each, and discounted $262.50
12uF retail $360 each, and discounted $270.00
15uF retail $475 each, and discounted $356.25
20uF retail $576 each, and discounted $432.00
Call to order: 940-592-3400
Here are the Dimensions of the caps in inches:
             Length    X    Diameter
5uF=       2.5”       X      1.625”
6uF=       2.5”       X      2.0”
6.8uF=    2.5”       X      2.0”
8uF=       2.5”       X      2.0”
9uF=       2.5”       X      2.25”
10uF=    4.95”      X      1.75”
12uF=    4.95”      X      1.82”
15uF=    4.95”      X      2.0”
20uF=    4.95”      X      2.5”
The leads AWG are 18AWG for the 5uF through the 9uF.
Leads on the 10uF through the 20uF are 16AWG.
All use solid Copper wire with 99.99% purity and Tinned leads.
« Last Edit: 19 Jul 2019, 06:08 pm by Danny Richie »
Early B.
Re: New Copper Caps and pricing
« Reply #1 on: 18 Jul 2019, 12:27 am »
I suppose I'll jump out there and be bold enough to ask the questions others may be afraid to ask:
Are these rebadged Miflex caps? If not, and since they're in the same price range, how do your caps differ/compare to Miflex caps?
mresseguie
« Reply #2 on: 18 Jul 2019, 01:45 am »
Newbie question:
Can these be used on any component (preamp, amp, DAC, crossover)?
Early B,
Thank you for asking the question.
« Reply #3 on: 18 Jul 2019, 03:35 am »
Newbie question:
Early B,
speaker / cross over  voltage,  not  for high voltage electronics  circuits
Early, no , not   relabeled  Miflex caps,   these  were  done  from the  ground  up with high purity  copper  I believe  was sourced  from Germany
Jay
« Last Edit: 19 Jul 2019, 04:35 pm by Captainhemo »
celebrat
« Reply #4 on: 18 Jul 2019, 01:22 pm »
Danny
Will these be a good (albeit expensive) upgrade to the Sonicaps and Erse for the NX-Oticas?
Danny Richie
« Reply #5 on: 18 Jul 2019, 01:46 pm »
Development of these actually started before the Miflex caps were brought into the US. These are US made caps.
These are also lower voltage caps and not as big physically as the Miflex caps.
Danny Richie
« Reply #6 on: 18 Jul 2019, 01:47 pm »
Danny
Yes they would.
Danny Richie
« Reply #7 on: 18 Jul 2019, 01:48 pm »
Newbie question:
Early B,
They can be used in anything that is low voltage. So coupling cap positions or in a DAC is fine.
« Reply #8 on: 18 Jul 2019, 03:08 pm »
These look more like the Jupiter low voltage caps, but using even better quality copper than they use, is that correct?  If so, that's a HELL of a deal you have going on Danny.
Early B.
« Reply #9 on: 18 Jul 2019, 03:28 pm »
Tyson -- you're probably in a great position to conduct a cap shoot-out between these, Miflex and Jupiters. Some of us are curious about the sonic merits of these caps.
gab
« Reply #10 on: 18 Jul 2019, 03:45 pm »
+1 on a shootout Tyson :thumb:
Danny Richie
« Reply #11 on: 18 Jul 2019, 03:56 pm »
Yes. The company that is making these caps once also made the Jupiter caps. So they are quite good and very experienced at making caps of this type.
« Reply #12 on: 18 Jul 2019, 04:10 pm »
Sure thing, just let me set up the GoFundMe page :lol:
mlundy57
« Reply #13 on: 18 Jul 2019, 04:35 pm »
 :rotflmao:
jtwrace
    • TIPP YouTube Channel
« Reply #14 on: 18 Jul 2019, 04:51 pm »
And we all thought you wanted to take your S7's to the next level.  :P
« Reply #15 on: 18 Jul 2019, 04:54 pm »
You know, before the divorce I would have had the $$ to do it, but money is tight when you get divorced in CO.
I compensate by pulling my speakers halfway into the damn room any time I want to :P
jtwrace
« Reply #16 on: 18 Jul 2019, 05:15 pm »
I totally get it!  Maybe Danny will send some to his favorite S7 owner to try and report back to the other followers.   ;)
Edit:  Then you and Pez can add to the Tuesday Tech Talk..   :lol:
Early B.
« Reply #17 on: 18 Jul 2019, 05:50 pm »
Oh, Tyson -- the fact that you could afford to get a divorce tells us you have plenty of money for these caps. Just do it, man, so we can hear your system vicariously.
If it made sense for me to do it, I would, but the number and values of the Copper Caps I need cost a few hundred dollars more than what I paid for my speakers. :o
SoCalWJS
« Reply #18 on: 18 Jul 2019, 08:06 pm »
If I understand this correctly - for the S7 you would need a 10 & 15 for each speaker to replace the 2 Sonicaps?
Jeff
  • Test...
    • Sonic Craft, Inc.
« Reply #19 on: 19 Jul 2019, 02:59 am »
Congratulations!  What is the tolerance?  Lead material and gauge?  Did they use paper only, or paper and poly?
(Edit)Oops!  I did not see your other post regarding the lead material.  I could not tell that they were tinned leads in the pic.  I was just curious if you went with the 4/9s solid Silver like the Jupiters.  I'm still curious what gauge lead though.
Same Copper.
« Last Edit: 19 Jul 2019, 03:59 am by Jeff »
