Evolution of a Crossover Upgrade
0 Members and 1 Guest are viewing this topic. Read 7016 times.
Keithh
Re: Evolution of a Crossover Upgrade
« Reply #20 on: 29 Jul 2019, 05:03 am »
Sure hope you don't still have metal screws holding down your coils.
A metal screw through the center of a coil can easily change the inductance of the
coil by 10-20%.
mkane
« Reply #21 on: 29 Jul 2019, 02:02 pm »
Thanks. I'll change that now
mkane
« Reply #22 on: 29 Jul 2019, 02:27 pm »
 It's done
Wind Chaser
« Reply #23 on: 29 Jul 2019, 02:50 pm »
Having removed the screws, can you hear a difference? Did it correct the upper stridency?
They're a bit stringent up top...
mkane
« Reply #24 on: 29 Jul 2019, 02:53 pm »
 Using the super Minis at the moment. Give me 10 minutes and I'll switch these out and give an impression.
« Reply #25 on: 29 Jul 2019, 03:04 pm »
If you  switch them out,   listen to the wedgies both with and without the screws, otherwise, you're going  from memory with  another pair of speakers inbetween... hard to  do.
jay
mkane
« Reply #26 on: 29 Jul 2019, 03:34 pm »
 Thanks,Capt. That did it. We now have a fantastic top end. It's the way it gets there, very fast, no roll-off, sharp and very clear. I like the way these speakers keep up with the music. We have way to much gear in this house, at least 3 of everything. The phono pre I'm using is a Herron, the deck is a souped-up AR ES 1 with a Shelter 501. Happy camper.Listening to Mark Isham 'Vapor Drawings'.
mkane
« Reply #27 on: 29 Jul 2019, 04:02 pm »
 Back and forth with-without. same song. Blanket's removed. Readily apparent the 1/4-20 screws had an adverse effect. Thanks, fellas. I'll finish these soon.
Wind Chaser
« Reply #28 on: 29 Jul 2019, 04:33 pm »
Awesome. That's what makes this place so great!  :thumb:
Early B.
« Reply #29 on: 29 Jul 2019, 04:55 pm »
OK, now I have a question -- I have metal screws next to my inductors, although none of them are placed in the "doughnut hole" of the inductors. Are these screws interfering with the inductors?
mlundy57
« Reply #30 on: 29 Jul 2019, 05:16 pm »
What would be a good way to hold an inductor down if I wanted to make the crossover look pretty, say a wood disc on top of the inductors instead of the zip-ties?
 Mike
gab
« Reply #31 on: 29 Jul 2019, 05:22 pm »
 Mike
http://www.troelsgravesen.dk/tips.htm
see very first part of the page
mkane
« Reply #32 on: 29 Jul 2019, 06:37 pm »
^^^^^^^^tip of the day. Thank you. I'm using double-sided tape for the time being. And you could use silicone to hold the wood cap on for good looks.
« Reply #33 on: 29 Jul 2019, 06:39 pm »
We've used   clear  silicone    and   also have used  hot glue.   I was worried  about the hot  glue possibly melting   the  varnish/insulator on the inductors  but   no issues so far .
jay
mkane
« Reply #34 on: 29 Jul 2019, 06:40 pm »
 My chores are done. Time for some sit down listening. Tables out of the way.
« Reply #35 on: 29 Jul 2019, 07:13 pm »
Yummy!  How do they sound?
mkane
« Reply #36 on: 29 Jul 2019, 07:20 pm »
 Excellent. Spinnin' I Robot
