X-SLS Encore build
Re: X-SLS Encore build
« Reply #40 on: 6 Feb 2020, 12:42 am »
Finally managed to get a little acoustic treatment up in the listening room and a new rack.
These babies continue to impress!
I busted out the fish-eye lens  8)
Very nice!  Yeah, treating your room is like upgrading your entire system :thumb:
Wigand
« Reply #41 on: 17 Apr 2020, 10:21 am »
Both the SLS and the MTM looks amazing. Do those feature the same parts (Crossover, Woofer, Tweeter) and is the only difference the added woofer?
mlundy57
« Reply #42 on: 17 Apr 2020, 02:34 pm »
The crossovers are different
Wigand
« Reply #43 on: 17 Apr 2020, 05:15 pm »
Ok thanks; but its the same "Class" of speaker regarding soundquality.... ?
Wigand
« Reply #44 on: 17 Apr 2020, 05:16 pm »
I am Looking for a system that does not need a sub because the listening space of my room is only 10x12 feet :)
Wigand
« Reply #45 on: 17 Apr 2020, 06:17 pm »
btw. do you have the cabinetplans of the MTMs? Couldnt find them on Dannys page sadly
mlundy57
« Reply #46 on: 17 Apr 2020, 06:32 pm »
Yes they are both X-Series speakers and use the same drivers. The Encore versions of both use the Peerless tweeter and M165 woofers.
The MTM plays deeper and has more midbass to midrange body than the SLS. While both will benefit from a sub, if you aren't going to use one, the MTM is the better choice.
I do have plans for both of those. Danny has the plans, maybe he'll post links to them. Otherwise I can send them to you.
Mike
Wigand
« Reply #47 on: 17 Apr 2020, 06:34 pm »
Thanks for the answer; I  already found them posted by Danny here: https://www.audiocircle.com/index.php?topic=90911.40
Thanks again
RonP
« Reply #48 on: 31 Aug 2021, 02:07 pm »
Sorry for the thread Necro, but I'm cross posting some updates from another circle.
https://www.audiocircle.com/index.php?topic=177976.msg1872621#msg1872621
I've upgraded the Sources, PreAmp, Amp and added more room treatment. I continue to be amazed how well these 4 little drivers perform. They play back exactly what you throw at them.
RonP
« Reply #49 on: 20 Sep 2022, 11:04 pm »
