0 Members and 1 Guest are viewing this topic. Read 8068 times.
This can be a simple thing. Get both with a money back guarantee and then listen to both. Opinions are just that. Use your own ears to decide PERIOD .charles
As I'm sure we all know, it's not just about volume. It's about driver control, transient attack / dynamic swings, and ease.For example:My speakers are 90 db and a relatively flat load. I've lived with them for over 10 years and I don't find them particularly hard to drive. They sound glorious run full range with a quality 50 to 100wpc amp. I typically listen at about 75 to 80 db. When I use my 20 wpc P/P tube amp it gets more than plenty loud enough, and your chart says it will reach over 100db, but it just doesn't sound "right". Sound is sluggish, distant, a bit veiled, lacks transient attack and dynamics, and the bass is soft and tubby. Why? Because the amp cannot properly control the 10" woofer. Simple as that.As further proof of this bottleneck, when I passive biamp and use this same amp on top part of speaker only (plus a more powerful amp on the bottom, either tubed or SS) the sound is real good. So when run full range, despite the fact that this amp's 20wpc can crack my eardrums, it simply doesn't produce the "right" overall sound due to it's inability to "control" the drivers properly.
YES! Absolutely agree and well stated. This has been my dilemma. I did not notice any deficit when I compared my parallel 300b SET to single tube circuit amps, EXCEPT on one bass heavy track that to me just did not sound right. I think the amps cover 95% of my listening. This doubt made me order a new custom push pull Allnic amp - M2500 push pull for 20W PX25 tubes. (300b 30W or KT150 100W continuous standard). These amps are unique because it uses a tube rectifier in place of solid state circuit design (conversion to DC power). I am hoping the best of both worlds. Objective and clean with tight bass seen in push pull design while retaining the musical qualities seen in SET amps. The amps are a new design and not seen in US to date.It's an experiment and an investment. I'm investing in custom amps because I like the character offered of the PX25 over the 300b.My aural memory sucks. I can not assess adequately unless I have the amps in the room together and ideally the same tube type and manufacturer.
Hello, I am desperate for advice. I am looking for an amp for some Zu DWs that I recently purchased. They are 97dB and 12 ohm. I have a small room (16x11). I listen to everything including large orchestral works and death metal. I don't listen loudly, I am also not a bass freak, but I like to "feel" the music at times. I have boiled down my choices to a Decware SE84UFO2 or a Coincident Dynamo with 300b tubes. I am worried that I will run out of headroom with either of these amps, but especially with the Decware. Can anyone offer any advice or experience? Thank you.
This is why I love my Super 7 speakers so much - flat impedance, high sensitivity mid/high drivers and percussive, super controlled self-powered bass section. Cause tube amps do mids better and ss amps do bass better, IME.
