DAC/Streamers
0 Members and 2 Guests are viewing this topic. Read 90153 times.
CanadianMaestro
Re: DAC/Streamers
« Reply #60 on: 30 Aug 2019, 01:18 pm »
Methinks that people who own the Bryston separates (player + DAC) and use an updated version of Moose will not need to update, as they will already have streaming capabilities.
Still, this new product looks like a very nice "entry" for newbies who want a taste of the Bryston house sound without breaking the bank on separates. Also may be suited for a more compact second system in the home or office.
  • The Demo is Everything!
    • http://www.bryston.com
Re: DAC/Streamers
« Reply #61 on: 30 Aug 2019, 03:07 pm »
Hello James, is it possible to update BDA3 to this? how much will it be the cost in case?
Hi Grant
No sorry the BDA3.14 has a totally different chassis and connection points - also I do not think you would want to if you already have the BDA3 and BDP-3.
james
Grant Hill
Re: DAC/Streamers
« Reply #62 on: 30 Aug 2019, 04:05 pm »
ok thanks James - I have not the BP3 (still)  :D
soundmax
Re: DAC/Streamers
« Reply #63 on: 30 Aug 2019, 04:24 pm »
Hi James,
Does bda 3.14 have the new Raspberry PI 4 inside?
Re: DAC/Streamers
« Reply #64 on: 30 Aug 2019, 06:38 pm »
Hi James,
HI
No it uses the 3 for now. The PI is a separate board so it would be easy to replace it going forward if the performance warranted it.
james
vakavanha
Re: DAC/Streamers
« Reply #65 on: 31 Aug 2019, 08:32 am »
What are the max resolutions thru ethernet like using Roon?
schmidtmike76
Re: DAC/Streamers
« Reply #66 on: 31 Aug 2019, 01:31 pm »
HI
james
this is where I respect the Bryston approach only if it warranted it.  James, thank you for the honest approach while still expanding you’re catalog.
Re: DAC/Streamers
« Reply #67 on: 31 Aug 2019, 02:43 pm »
Hi
192/24
james
gdbalp
Re: DAC/Streamers
« Reply #68 on: 31 Aug 2019, 07:24 pm »
Hi James,
Very excited about this new product offering... :thumb:
A have a few questions:
1) Same DAC chips as in the BDA-3?
2) With an internal CPU, can a hard drive be installed?
3) Can the display be seen on an external attached monitor?  Great if it was interactive too...
4) I2S, same as PS Audio format?  Can outsource the I2S to external DAC?
5) "Bryston’s ultra-precise re-clocking circuit reduces jitter to nearly unmeasurable levels" - What does this mean vs. BDA-3?
6) With this CPU, there would be three separate power supplies inside this unit?
7) Why call it BDA-3.14, should it be something new like BDPA-1  (PLAYER/DAC combined)
And the tough question; Does it sound better than the BDA-3 and BDP-3 combination?
Luigi
Stu Pitt
Re: DAC/Streamers
« Reply #69 on: 31 Aug 2019, 10:11 pm »
My reservation in single chassis digital sources such as these is obsolescence. Digital formats/codecs/whatever they’re called come and go seemingly quickly. DVD-A, HDCD, SACD, DSD, MQA... what’s next? Having everything in one box typically means getting rid of the whole box, including the stuff that’s not obsolete.
If the boards are changeable/upgradable as James said, then that changes my view on it. I always think of my father’s old receiver with built-in 8-track. The amplification was fine for quite some time after 8-track was a distant and funny memory. I was contemplating the original Naim Uniti when it came out. It had CD, streamer, DAC, etc. built into it. Having stuff in one box that will go obsolete sooner or later is a big part of why I went with the B60 instead. Not the only reason, but definitely a major one.
I like to keep digital sources as separate as possible. If it’s upgradable, and for a price that’s makes it worth it not to throw the whole thing out, then that changes my view.
TJ-Sully
Re: DAC/Streamers
« Reply #70 on: 9 Sep 2019, 02:05 am »
Hi Grant
james
Hi James
Have you, or anyone at bryston tried an A/B test with the new BDA3.14  vs.   BDP3>BDA3 setup?
cheers, TJ
Re: DAC/Streamers
« Reply #71 on: 9 Sep 2019, 11:18 am »
Hi James
cheers, TJ
Hi TJ
I have not yet done the comparison as there is only one 3.14 in existence and Gary has that one at the show.
That being said there were 2 major reasons we developed the BDA3.14.
1. I wanted a lower price point for those customers wanting to purchase a Bryston ...  Preamp and Streamer and DAC.
2. There seems to be a going market now for integrated components over separates.
Technically and feature wise the separate BP17/BDA3/BDP3 have superior measured performance.  Whether that translates to the listening experience will be interesting to see.
james
alexone
Re: DAC/Streamers
« Reply #72 on: 9 Sep 2019, 07:24 pm »
...exciting times, James :thumb:.
makes me really curious what's next in the Bryston lineup talking about integrated components :drool: :drool:
i always knew you guys can do it!
al.
mav52
Re: DAC/Streamers
« Reply #73 on: 11 Sep 2019, 02:28 pm »
Hi
Yes the higher bit rate DAC's allow for much better signal to noise if using a digital control.
The Volume control can be turned on and off if using a preamp.
james
How will the volume be controlled, remote or front panel  or do you have to use a pre-amp
Re: DAC/Streamers
« Reply #74 on: 11 Sep 2019, 07:27 pm »
Hi mav
You have the choice - the remote GUI for volume so you are using the Pi as a preamp as well or you can connect the 3.14 to your preamp.
james
mav52
Re: DAC/Streamers
« Reply #75 on: 12 Sep 2019, 10:23 pm »
Thanks James
alexone
Re: DAC/Streamers
« Reply #76 on: 13 Nov 2019, 08:32 am »
James,
the BDP Pi can put out DSD up to 128 via its usb connections ?? :scratch:
al.
« Last Edit: 13 Nov 2019, 09:47 am by alexone »
Re: DAC/Streamers
« Reply #77 on: 13 Nov 2019, 12:12 pm »
James,
al.
Hi Al,
The 3.14 using the Pi can do DSD 128 but converts it to 192.
james
Re: DAC/Streamers
« Reply #78 on: 6 Feb 2020, 07:19 pm »
SUBJECT: Bryston 3.14 DAC/STREAMER/PREAMP REVIEW
Music and movie streaming is becoming increasingly popular at an astonishing rate.
Introducing Bryston BDA-3.14 Streaming DAC
Streamers and streaming services have been here a while but are really now taking hold of the music and movie delivery to consumers at home and anywhere they are located using their phones or tablets.
I put off setting up streaming because (1) I have all my music on hard drives connected to OPPO BDP-105 and UDP-205 players, using a phone and tablet app that shows me a directory of the music which I can play by simply tapping on an album or track; and (2) I am not very proficient with manipulating my wireless network. This article is Part 2 of my project on showing our readers how easy it is to set up music streaming.
Bryston has released their new BDA-3.14 Streaming DAC. As the product name implies, it has a streamer combined with a built-in DAC which is capable of up to 32/384 PCM and DSD-256. For streaming, the highest resolution available is 24/192 FLAC, but you can use the separate DAC inputs for higher resolution files input from other sources.
The Bryston 3.14 hardware sounds superb with the music that I listened to from the Qobuz streaming service.
I will have a full review of the BDA-3.14 soon.
John E Johnson Jr.
Re: DAC/Streamers
« Reply #79 on: 6 Feb 2020, 07:25 pm »
Bryston BDA-3.14 Renderer+DAC
CHRISTIAAN PUNTER 1 February 2020
RTFM (Read The Friggin Manual). Yeah, but that doesn’t go for me, right?
After fiddling with the BDA-3.14 for quite some time and getting no sound out of it using any of its inputs I was convinced that it was not functioning as it should. So, I reached out to the distributor via email, only to reluctantly pick up the manual while waiting for a response. Upon browsing it, I found the below A4 print…In my defense: the unit does not have any volume control buttons nor does it indicate its volume status on the front panel, and so, I was not aware that it even offered a volume control.
Its startup volume setting is around 50% and that’s attenuated enough to appear as silent with a regular volume setting on the CH preamp. After a restart, it returns to this setting even if it was raised before. This is a necessary safety feature that prevents heart attacks and damage to speakers but that nevertheless also always annoyed me when using any Wadia product. Fortunately, contrary to those Wadias, the BDA-3.14 allows the user to define the default startup level via its dashboard that is accessible via any web browser.
Functionality
The BDA-3.14 is Bryston’s current reference DAC and with its many inputs, streaming capacity and built-in volume control, it is meant to perform the central role in a multiple-digital-source system. If I explain that the BDA-3.14 contains the BDA-3 DAC as well as the contents of the BDP-Pi, can you guess what inspired the model number? Indeed, it’s mathematical constant Pi! Containing the contents and functionality of these two boxes in one for only 430 euros more than the basic BDA-3 DAC is a very good offer. The streaming component is not just slapped on either but properly connected via I2S which is the best possible connection. The BDA-3.14 has an unprecedented amount of inputs among which are two USB ports (jay!), 4 HDMI ports, AES/EBU, SPDIF on coax, SPDIF on BNC, TOSLink and a network connection. The built-in firmware has advanced a lot since the last time that I used a Bryston streamer and the current Manic Moose version looks modern, solid and intuitive while offering a wealth of configurable options.
Accessible via any web browser on any network-enabled device by typing my.bryston.com, the user is able to access all of the front panel functions in addition to a very wide range of other functions, including volume control. Just like with Antipodes servers, the BDA-3.14 offers user-selectable compatibility with a range of playback methods such as MPD, RoonReady, Shairport-Sync, Squeezelite, DLNA/UPnP as well as access to a Samba share.
The unit plays back PCM and DSD from the network as well as from USB thumb drives. For its simplicity and stability, for many users, the built-in Bryston Media Player will be the interface of choice. While I found that it works intuitively, quickly and very well indeed, I’m afraid that I am intertwined too much with the Roon interface to much like any other interface anymore.
Importantly, I found it is 100% stable also when using Roon. Besides local sources, the unit also offers an internet radio directory named bRadio and works with Tidal and Qobuz.
The manual also contained a leaflet that indicates that a nice remote control will be included later. As I noticed too late, the picture of that unit also contains volume up and volume down buttons. This is great for minimalistic systems that contain no analog sources but I still feel that the front panel should have an indication of the volume level for this to work on a level that I would be comfortable with.
As I wanted to compare the BDA-3.14 to other DACs in a similar price class that do not have volume control I did not further investigate this possibility but I have no doubt that it will work well. From Roon interface, the BDA-3.14’s volume level can be controlled directly.
Bryston notes that the maximum output from the BDA3.14 RCA connectors is 2.0V and 4.0V on XLR balanced and that an amplifier with a gain of 29dB can generate 100 watts with only 1-volt input. The manual does not state how the volume leveling is implemented but I would assume it is done digitally. Now, some people might be hesitant with respect to digital volume leveling but I use a digital volume control with the CH Precision C1 myself every day and can honestly say that it is often a better solution than an analog level control. The DAC stack above was only for quick initial comparisons. The final judgments were made with each DAC sitting by itself directly on the Artesania platform.
Review Context
The BDA-3.14 will be assessed in a system comprised of the CH Precision L1 preamplifier and A1.5 power amplifier with Martin Logan ESL15A and Magico S1 MkII loudspeakers. The digital source, as always, is the Antipodes CX+EX music server. For further comparisons, I also have the Aqua Formula xHD, Jay’s Audio DAC-2 Signature and the Denafrips Venus DACs as well as the Jay’s Audio CDT-II MkII and Aqua La Diva CD transports at hand. The interlinks used are Vermouth Reference between the DACs and the preamplifier and CH Precision Balanced Link between preamp and power amp. Finally, the speaker cables are Jorma Design Trinity and the power cables all Belden with Bals schuko- and Oyaide C-004 IEC connectors.
The BDA-3.14 was a demo model that had already seen use but I also allowed it plenty of time to come on song. That was more as a “just in case” than a necessity as I don’t feel that Bryston products need much if any warming up.
Listening
I started my listening to the Bryston BDA-3.14 after a long day at work without any prior comparisons. Connected at this time were the Magicos with the Aqua La Diva CD transport as a source. That’s because I am currently in a kind of CD-mood and as a result am comparing various CD spinners.
Anyway, the BDA-3.14 sounded really great!
There was absolutely nothing standing out that I could pick at and nothing obviously missing and it all seemed just perfectly proportioned. There was great resolution, perfectly natural timbre (no artifice) an overall solid sound with lively dynamics and without any hardness or edge. Along with the propulsive liveliness, there was also a subtle
smoothness and fluidity that prevented the sound ever becoming dry. And, as I have found out during earlier Bryston tests, if a product sounds fluid and smooth with the Magicos, then you can certainly trust that this really is the case. Now, certain products achieve a forgiving sound by sounding overly smooth but with the BDA-3.14 this is absolutely not the case. It is slightly smooth but also propulsive and lively.
Now it was time to switch to the Antipodes CX+EX music server with the aim to compare USB sound to Streaming sound, as well as to make a generic comparison between the Music Server and the CD transport. After having set the BDA-3.14 to RoonReady in the dashboard (it was in UPnP mode when I got it), the device was found by Roon immediately. Starting with the EX as the renderer, connected to the BDA-3.14 via Final Touch Audio Callisto USB cable, the sound was even more sonorous and spacious but less articulate and less spritely. The sound was still dynamic but more static than with the CD transport. This has nothing to do with the BDA-3.14, though, it is a difference that I have noticed with any DAC. The Aqua transport is just that spritely. Switching the USB cable from the EX to the CX so that the server and renderer are on the same device makes for a more nimble and articulate sound closer to that of the La Diva but I’m not sure if I prefer this leaner sound to the room-filling fullness of the EX. For more in-depth descriptions of these options please refer to the Antipodes review.
Streaming input
When bypassing the EX and CX’s renderer function and the USB cable and using the CX as a server only (just as I do with the CH Precision C1’s RoonReady ethernet input board) the BDA-3.14 all of a sudden strongly reminded me of the Bryston BDP-3 media player. Now, the sound was very close to that of the La Diva transport. Tighter, nimbler and more articulate as well as more direct, the Aqua transport remains the most energetic source but there is also a lot to say for the server sound. It seems that the physically more direct connection really also results in better sound. It’s always good to have lots of options, especially when talking about digital inputs. As the CD transports clearly illustrates, the DAC portion of the BDA-3.14 is really great. But especially when compared to the Antipodes server, it’s with its built-in streamer section that the BDA-3.14 is most impressive.
Speaking of options, I also have the 2500-Euro Jay’s Audio CDT-II MkII CD transport (top right) which is really interesting because unlike the La Diva and any other transport still available that I am aware of, it uses the famous Philips CDM4 swing-arm mechanism. This mechanism has a unique sound and the Jay’s player proper implementation of it results in a sound that is very fluid and utterly free-flowing combined with a big and rich bass. In terms of the latter, the Jay’s CD transport has a sound that is closer to the Antipodes EX sound and less similar to the La Diva transport.
In practice, when choosing between these two CD transports, this means that the user has a choice for a fuller, more relaxed and more free-flowing sound or a more urgent and more spritely sound. The former is more forgiving, the latter less so. The Aqua is more audiophile to a level where I even prefer it to the music server but at almost 8000 Euros it is also considerably more expensive than the Jay’s.
In any event, the BDA-3.14 clearly demonstrates the differences between these sources meaning that there is nothing wrong with its transparency.
Yes, there are more transparent DACs. The Aqua Formula xHD and the Denafrips Venus are both more highly resolving and more transparent. Both DACs use a discrete NOS R2R topology which gives them a cleaner, higher-res and more direct sound than most other DAC topologies. On an absolute scale, I would say that both these components offer more insight into the recordings and as such can be considered to be more high-end than the Bryston. In the case of the Aqua, there is no shame in that because the Formula xHD costs 13.670 euros. In the case of the Denafrips, the situation is more competitive as the Venus is more or less in the same price range as the Bryston. But here it becomes a matter of choosing between a pure DAC with more audiophile sound and a DAC that includes a ridiculously good sounding streaming endpoint as well as the largest selection of inputs that I have seen on a DAC yet. While both the Aqua and Denafrips DACs are more transparent and refined, as I mentioned at the start of this review, this is only evident upon comparison and that makes it a little bit more relative. The Jay’s Audio DAC-2 Signature, finally, also offers a very interesting perspective. At 3000 euro, it costs less than the Bryston so the question begs: how does it compare? As I already noticed during the Jay’s review, the DAC has an unusually solid and chunky sound, reminiscent of the classic Wadia DACs. When compared with the Bryston BDA-3.14, itself certainly not feeble or thin sounding, this still remains so.
The Jay’s has an appealingly lifelike midrange that makes for a very communicative sound and in comparison, the Bryston is smoother and even a little creamy through the mid-bass and lower midrange. While the other DACs confirm that the Bryston is slightly on the smooth side of neutral it is also true that the Jay’s is a little dry, just like the classic Wadias. Its dry treble goes hand in hand with more articulate bass and so this is a benefit as well as a potential pitfall. But this also makes that the Jay’s DAC works so very synergistically with the Jay’s transport. With the Martin Logans, I find that all the DACs have their perks and none of them have any obvious flaws. With the Magicos, however, it became clear that the Bryston DAC has slightly better resolution and a wider soundstage than the Jay’s.
Conclusion
Clearly, the BDA-3.14 is a great DAC with a truly excellent streamer section on board. The latter is not just slapped on but implemented so well that the result is an even better sound than via the Antipodes CX+EX server. When used as a standalone DAC using its SP/DIF input with any source, it holds up strong, even in comparison with much more expensive DACs. The BDA-3.14 has a solid and immediately likable sound with great resolution, perfect natural timbre (no artifice) and lively dynamics and without any hardness or edge. Along with the propulsive liveliness, it also has a subtle smoothness and fluidity that makes the end result revealing yet forgiving.
