0 Members and 2 Guests are viewing this topic. Read 14268 times.
How about the Brennan B2?https://www.thebrennan.com/?gclid=EAIaIQobChMI1ZXjl6yD4wIVknQBCh2cEQesEAEYASAAEgJwT_D_BwE
I would check out both Naim and Linn and if you can avoid xlr then a slim-line marantz receiver. You can consider for about $150:https://www.hifiberry.com/shop/bundles/hifiberry-dac-xlr-bundle/Reasonable sized SDXC card Install volumio.org image in the sdxc card through an easy application and plug in ethernet for first boot to configure. Install the Linn Kazoo app to control the volumio and if you enable software volume control you effectively have a built in Preamp. It will have airplay, bluetooth, etc etc. Sounds highly technical, something that would continue to make me dependent on others for help. And no local Naim or Linn dealers.You can even get a second one with a headphone instead of XLRs.
Just get one of the Bluesound Nodes 2i or Vault. No fuss, very easy Roon compliant, run from tablet or phone, no friggin USB! It sounds very good with Qobuz, Tidal Spotify etc. and you are going into a PS Audio Jr. DAC anyway.Must use good cable! Never a problem on my eerO network, flawless.Buy from Audio Advisor no tax, free shipping and return if you don't like it.My primary concern here was getting rid of the computer, accomplished.
AsgharWhy don't you look on the PS forum and pick up a used Bridge II? Will do what you want with the two streaming services and one less IC and PC. While the mControl software may not be the greatest (Bluesound isn't either) it will do the job you want to do.
AsgharI've had a Node 2 in for demo as well as owned an Aries Mini, Aries Femto, Oppo Sonica, Lumin D1 w/SBooster LPS and the Bridge II was better in my system than all of them. It was slightly bettered in some instances by the Teac NT-505 which requires you to use it's internal DAC and the Aries G1, both of which are in the $2500 range. That may also be true of the Aurrender and Innuous models in that price range as well as the Lumin U1 Mini but I haven't heard any of them. In my testing three years ago the Aries Mini handily defeated the Node 2 so it went back to AA and I kept the Mini so the Node to my ears is not in the same league as the Bridge II separate case aside. If you want the best sound and future flexibility, if there is such a thing, then it is going to cost. The Bridge II will be around for a least another year and then will be replaced at some point in the future by a network card of PSA's own design. The Bridge II is it's own circuit board and only shares the DS's power supply. It is the same board used by Ayre, Krell and others. If you don't want to try a Bridge II I would opt for the Aries G1 or the Lumin U1 Mini if you don't want or need the ripping feature of the Innuous. They both have a full compliment of outputs.
There are two for sale on the PS website for $400.
