0 Members and 1 Guest are viewing this topic. Read 6615 times.
OK...maybe this isn't exactly the same....but I'm driving the Salk Veracity STs which have the RAAL 70-20X Ribbon that crosses over at about 1.8kz with the 2Cherry amplifier...and the results are spectacular...These two pieces of equipment show off what the other can really do in the production of highly detailed and highly musical sound...I have no doubt that the Cherry Amps mated with Maggies, Eminent Technology LFT-8b and other similar speakers will be equally outstanding!!
I'd love to hear from a Maggie owner who has them paired to the Cherry.
I'm one, but biased just a bit (MMG, Mag 1.7i)
LOTS of Cherry customers running Magnepan speakers!! Not sure how many are on Audio Circle, though. Maybe post this question on the TRUTH in Audio group (Facebook) for more response:https://www.facebook.com/groups/TRUTHinAudio/....Some with 3.7s, and one 20.7 system with Cherry MEGA MONOs (review on the way).
I have the new LRS's and was wondering if the normal 48v 125 watt per channel version would be enough to drive them? My SS class A/B NuForce STA-200 at 80 watts per channel is not.
We have an email from you.... Hope to reply today. The Stereo Maraschino (STM) does a GREAT job driving 1.7i speakers, even very loud, so the LRS's would be no problem.By the way, we have a demo STM in stock. I'll tell you more in my email reply. Thanks.
If you are planning on Class "D" or digital no better amp out there for your application IMHO period end of story.charles
I have Acoustat 2+2s that I modified with adjustable high voltage supplies I designed and Sowter 1/100 transformers. I would love to hear what Mono Mega's would sound like and if the would even drive a load like this which drops to very low impedance at high frequencies. I use class A amps now. I had to add a series resistor to the primaries to keep the amplifiers from overheating. I cross to subwoofers of my own design and construction at 125 Hz using digital bass management. Another question I have is why do you not have a digital input? Everything in my system passes through a digital processor. My phone amp is converted to 192/24 by a Benchmark ADC. If your amps had a digital input I would not have to convert everything back into analog. Is there a way to add a digital input to your amps?Mike
Mike,We have considered this. We have made "direct digital" amps before, but the current lineup of Cherry Amps is analog. There's digital processing inside, but not A/D conversion in the traditional sense. It's more a hybrid approach, modulation-wise, so a digital input version would essentially be a DAC DAC driving the amp. Putting the DAC inside eliminates the interconnects. There's also the possibility of designing a new "direct digital" amp (digital-only modulation) using what we've learned since our last one, but performance would need to be comparable to our existing amps. That's no small feat! This is something I think about almost every day, so you've stirred some new motivation up (:By the way, we might have a pair of demo MEGA MONOs soon (early July).... Thanks for your kind post, and have a great weekend.Best Regards,Tommy
What are the current ratings of your amps? Just curious as Maggies like high current amps.
20-50A max, depending on model. You can calculate max current with power and load resistance (impedance, but we're simplifying to a scalar for purposes of this comment)....(current is "I", voltage is "V", resistance is "R", power is "P"):Prms = Vrms^2 / R = Vp^2 / 2*R, and Ip = Vp / R, so....Ip = Vp / R = sqrt(2) * sqrt(Prms / R) = 0.707 * sqrt(Prms / R)So, for a Cherry MEGA putting 1000W into 4Ω, Ip = 22.4AThus, 50A capability is not really a meaningful limitation into 4Ω! In fact, it's not even a limitation at 2Ω, which simply requires twice the current (<45A).
Thanks, I was just curious. I think that listing the current of an amp can be helpful when trying to pick an amp with speakers like Magnepans that can sound better with higher current. Of course there is more to it than that on many levels. My Parasound A21 is rated at 60 peak amps, more than my Pass amp I believe but it does not sound nearly as good as the Pass. Both are listed as 250 wpc at 8 ohms but the Pass is 500 wpc at 4 ohms and the A21 400 at 8 ohms.
