0 Members and 1 Guest are viewing this topic. Read 6671 times.
I purchased Custom Studios a couple years ago and I have only listened through them a couple of times. I bought them because my Sony headphones disappeared (somebody took 'em).They were approx. $400 CDN, I didn't want to spend more. Comparing to other brands at the store, on careful listen these seemed to have the clarity I wanted, though the differences are subtle. It has a switch to adjust the sound to 1 of 3 setting.I plug them into mixer. Don't know if I need a headphone amp, they sound okay. Mainly listen through loudspeakers which is why I haven't used them more.
Be interesting to find out.....are your T70's the only Beyers you have?Would you share your mod on these ?
Correct me if I am wrong, but the HD700 is a Sennheiser headphone as well as the HD600 and HD650?So how is this related to Beyer products?Am I missing something here?Think I need to start a Sennheiser discussion thread !! Agreed, the only time that a Sennheiser should be mentioned is when comparing a model directly with a Beyer and we should refrain from adding other Sennheiser related things unless either modifications or experiences with a Senn model are directly related with a Beyer. Otherwise, what is the point?Alex
Tyson,Did you buy a pair? They indeed have several stellar reviews!The delta between the T1's and them are $3000 - 700 = $2300.Its almost like they are in differnt leagues....Can you comment on the sound differences in some more detail?Alex
