SOLD - please delete
0 Members and 1 Guest are viewing this topic. Read 910 times.
Mr Peabody
« on: 25 May 2019, 11:01 pm »
I Am original owner, smoke free, this unit is only a couple months old so you would have almost full warranty.  I have original double box and everything that was included.  The unit is still as new with no cosmetic damage. selling to fund another purchase.
The M50.2 is in NAD's Master series.  The only component of it's kind to allow listening while ripping and choice of just playing a CD or ripping it.  See the reviews, including Stereophile.
A couple tips, when streaming Tidal or similar the Ethernet connection is miles better than Wyfi and AES/BU is much better than coaxial.  I also preferred ripping to FLAC which is the factory setting.  An Ethernet bridge can be used if your router is not close by.
The 50.2 is ONLY a source with no DAC.  You will need a separate DAC or have one built into your amp or receiver.
Here's a list of features for your convenience:
•music storage device with slot-loading CD drive and 2TB internal hard drive◦2TB of mirrored backup storage
◦rips CDs as lossless FLAC files for convenient storage and excellent sound quality
•"direct ripping" of high-res files purchased from HDTracks — no computer needed
•BluOS compatibility for further expansion with Bluesound wireless speakers
•plays high-resolution music from CDs, internal storage, network storage devices, connected USB drive, or streaming services
•streams  high-resolution MQA songs and albums  from TIDAL MASTERS (subscription required)
•built-in dual-band Wi-Fi® for a robust wireless connection to your home network
•high-fidelity Bluetooth aptX® audio coding for greater sonic detail with compatible devices
•supported sample rates: 32kHz to 192kHz
•supported bit depths: 16-24
•solidly built chassis and heavy-duty front panel fight sound-muddying vibration
Bluesound Wireless Whole Home Music System:
•control the system with a free BluOS app for your smartphone, tablet, or computer (Android™, iOS®, Kindle Fire, Windows®, and Mac®)◦also controls other Bluesound players on your home network
•plays MP3, AAC, WMA, OGG, WMA-L, FLAC, ALAC, MQA, WAV, and AIFF files
•plays internet radio stations from TuneIn Radio and iHeart Radio
•Spotify® Connect support (Spotify app and premium account required)
•plays streaming music from services like TIDAL, Slacker, and Napster
•play and send music to multiple rooms when you add other Bluesound players
•works with Amazon Alexa-compatible voice control assistants
Connections and General Information:
•touch-panel display for play/pause/skip and other music playback controls
•front- and back-panel USB Type A ports for connecting a thumb drive with music files
•digital audio inputs: 1 optical, 1 coaxial
•stereo RCA inputs
•audio outputs:◦1 HDMI 1.4 audio (may require BluOS firmware update)
◦1 coaxial digital audio
◦1 optical digital audio
◦1 balanced digital AES/EBU (XLR)
•USB output for mass storage mode
•Ethernet port for a wired connection to a home network
•detachable AC power cord
•IR input allows control via optional IR repeater systems (not included)◦no remote included
•17-1/8"W x 4-9/16"H x 13-9/16"D
•weight: 17.9 lbs.
•warranty: 3 years
« Last Edit: 30 Jul 2019, 02:13 am by Mr Peabody »
Mr Peabody
Re: FS: NAD M50.2 streamer w/2TB HD/$$ drop
« Reply #1 on: 20 Jun 2019, 01:48 am »
If interested, make me an offer.
Mr Peabody
« Reply #2 on: 10 Jul 2019, 02:55 am »
bump
