0 Members and 2 Guests are viewing this topic. Read 27524 times.
OK, WTF just happened....????!!!A couple of weeks ago, I reported on the positive benefits of using cocobolo pen blanks underneath my preamp. Tonight, I tried Texas mesquite wood pucks cut straight from the branch. I simply removed the cocobolo squares from beneath my preamp and placed the mesquite pucks under the feet. Frankly, I was shocked by the difference in sound. There's no question that even the most ardent audio naysayer would have heard the difference. The sound became sweeter. I don't know how else to describe it. Definitely better, and not by a small margin. To make sure I wasn't losing my mind, I placed the cocobolo squares back in, played my favorite track, and then put the mesquite back in. Wow! Wait! It gets better!!! I placed the cocobolo squares underneath my DAC and there was a slight improvement. The mesquite/cocobolo combo worked out well for me. Of course, Elizabeth would encourage us to experiment with a variety wood types, but I'm good right here. I removed tube gear from my system because I didn't want to go down that rabbit hole. Anyway, for very, very cheap, you can tweak the sound of your system with wood. I can't explain it, so don't ask me to. Just try it. Hell, some of you can go in your backyard, cut some pieces from a fallen branch and see what happens. You might be surprised at the outcome. So what did we learn today, boys and girls? That's right -- wood is good.
Rollo: for comment "metal feet" of Magnepans...I own the later Magnepan 20.7s which have large oval wood base, (not the metal T shaped feet of old.) The speaker is up off the base by about a 1/2 inch. the brackets holding it up but to the base are thick aluminum castings, triangular support between the right angle brackets. The oval base of the 20.7 is 29" long axis, 15" wide axis, and about an inch thick. Pretty sure it is some sort of composite. ?? since it is painted, but is heavy... The oval is why I am using a combo if 6" 12" and 18" length wood under it.
