dac 10
nac
dac 10
« on: 21 May 2019, 03:37 am »
hi.what is the hi/lo gain button on dac 10 used for?
Wind Chaser
Re: dac 10
« Reply #1 on: 21 May 2019, 04:37 am »
It’s a very nice feature that allows for adjustment of the output voltage to better match the input sensitivity of the amp / amps.
nac
Re: dac 10
« Reply #2 on: 21 May 2019, 05:36 am »
yes I thought so. which would the sta9 mono amp setup be best served by,hi/lo?
Wind Chaser
Re: dac 10
« Reply #3 on: 21 May 2019, 05:49 am »
I would think the lower setting since it only takes 1.4 volts to bring the STA-9 to full power according to the specs.
RafaPolit
    • www.rafaelpolit.com
Re: dac 10
« Reply #4 on: 21 May 2019, 03:04 pm »
Indeed, within the NuPrime realm, stay with the low setting.
But, agreed, a very useful feature when matching to other types of components.
Rafa.
