AVP Preamp Won't Turn On
0 Members and 1 Guest are viewing this topic. Read 1353 times.
Evoke
    • EVOKE Planar Loudspeakers
« on: 16 May 2019, 11:22 pm »
My AVP shut off and won't come back on. I changed the remote batteries, checked the switch on the back, the power connection and the fuse. Is there anything else I can check on my end or is it .... I hope not .... the power supply?
Oh what should I do?
Thanks, Mark
ricardojoa
Re: AVP Preamp Won't Turn On
« Reply #1 on: 17 May 2019, 12:16 am »
Happened to me, sent in to Hong Kong nuprime authorized dealer to fix.
rustydoglim
    • www.nuprimeaudio.com
« Reply #2 on: 17 May 2019, 06:53 am »
HD-AVP ?
You are quite hands on, so please try to confirm that it is the power supply (open the cover, check the DC voltage out of the power supply, be careful not to touch the AC side!). Contact Nuprime support by following the process online.
Evoke
« Reply #3 on: 17 May 2019, 12:53 pm »
I would go ahead and do that except I learned my lesson about high voltage a long time ago. LOL ...  I'll check with the support folks at Nuprime :-)  Thanks, M
