0 Members and 1 Guest are viewing this topic. Read 13044 times.
My best first advice is shoot in RAW rather than jpeg.
To take it a step further, if you really want to learn how to use your camera, discipline yourself to shoot only in manual mode. This will force you to learn. The basic principles of photography are simple, but it takes a lot of practice to get consistently good shots. Now, if you just want better images than your cell phone can produce and just plan on shooting the grandkids on the weekends, then put that sucker on auto and be done with it. Just depends on how you plan to use your camera. Either way, the only other piece of equipment I'd recommend is a speed light. You can get a good, brand new one (not Canon brand) for $60.
With the 6D you can save it both ways. RAW and jpeg.I find this handy.
What is the point in that? Im not questioning you, I’m just trying to learn.
Well I just bought a new to me camera, my budget was only $300 clams. I bought a "kit camera" and now wondering if its just a toy?? or i am over my head. I only want to do recreational pics so not looking for professional results but still hoping I wont be disappointed.
The above statement says to me, "I want to shoot quality images, but I'm not trying to go pro." Like anything else in life, you will need to practice. There's no short cut for that if you want good images. This means you gotta shoot many thousands of shots before you begin to take consistently decent images. Sure, cameras are pretty smart these days and can perform most of the work for you, but those shots will probably be mediocre. It's the difference between putting your car on autopilot or taking the wheel. The autopilot feature will never floor it for fun, or rev the engine at a stop light, or honk at a curvaceous woman crossing the street.
As Early B stated, "It helps, for example, if you want to upload jpegs immediately on social media, but you still have the RAW version in case you want to edit them later".I use the jpeg to determine which photo may need editing... I use Light room for editing. If you are editing a photo always use a copy of the RAW file and keep the original unmolested.The 6D has many options but don't rush the learning process. Get out there and take pictures. Take notes and Experiment! Take some classes if you can and there are a bunch of online resources.Catalog your photos to make finding them easier. I usually save files by month and year. Sub folders to break them into events or particular importance in a particular time frame.. Use a method that makes sense to you. I keep a 4 TB hard drive for this purpose. Storage is cheap.Study how images look and try to determine what the photog was trying to capture..Turning this photo to black and white in light room brought a new meaning to this photo for me of a very special young man.Make the photos meaningful to you. That is what matters.Digital photography is a valuable resource for learning. Photograph in a way that pleases you and learn.Additional lenses are nice but not necessary to learn to take great pictures. They are a tool to use when needed.Don't feel that you need the latest and greatest glass and gear. The nut behind the shutter button makes the difference more than anything.As an example I took 325 photos of a sunset from a spot on Oahu. Bracketing so I could cover all situations. What I learned from that was manifold. It is worth the time and effort.For me the most important aspect is to have fun and learn. Your world will become much bigger.Enjoy photography and best of luck!
