Before you spend a lot of money on amps for these speakers, I'd highly recommend a little chip based amp like the Folsom model. With 94db sensitivity they just don't need a lot of power, and those amps sound about as good as any amps that I have heard.
Danny, could you pls post a double plot of acoustical output AND impedance?What frequency do you recommend for a line-level hi-pass filter for these?
...So any filter that removes the first two octaves will be fine.
OK; that sounds like a natural for the 0.022uF Miflex KPCU copperfoil/'propylene&paper/oils into a 100K load for 72Hz.TYVM.
Great job Dan! Are they a grayish white?
Wedgies are DONE! I used two layers of Raamaudio Raammat mass damper sheets to help damp both wings. I have no idea if it will help, but it certainly made a big difference with the knuckle test and the weight. Since I requested that Jay build my sub flat packs with 1” tops and bottoms (but 1.5” sides) for a uniform appearance after the grille recesses were cut, I acquired this Raammat to damp the interior panels of the subs due to the .5” reduction. I figured a couple of layers on the Wedgie wings might help. I then covered the Raammat with a layer of foam that I found on clearance. Now on to finishing the subs!...-Dan
Wedgies are DONE!
Danny23--where are you? Haven't heard from you since July 23.Did you get your atma-Sphere M60s running?
