0 Members and 1 Guest are viewing this topic. Read 4912 times.
I have Dynaco A25's.You have to pull the woofer to see the crossover cap on the rear wall of the cabinet. IIRC, usually an 8uF electrolytic if it is original. If it is original probably a good thing to update, along with checking the rotary switch for the tweeter level control. Some Caig Deoxit works well on the switch.I replaced the caps with polypropylenes and much better top end. Not bright just cleaner.They do not go low, but have decent bass response. Some of the woofers magnets have lost magnetic field strength, but an impedance sweep will find that. They are Alnico magnets and can be remagnetized by a woofer repair center.
