SOLD: (Los Angeles) Yamaha P5000S no-fan-noise pro amplifier! 500/700 RMS @ 8/4Ω
0 Members and 1 Guest are viewing this topic. Read 1113 times.
taloyd
Hello,
These are REALLY well made pro-audio amplifiers which have something special if the application is a quiet nightclub/acoustic music/home use - they are fan-assisted so the fans only come on when needed. For home use they'll basically never ever come on. Only selling as I found a P3500S which I feel better about because the P5000S was a bit too much power for my subs. Got the P3500S up and running and very happy with it - P5000S needs a home!
$373 + actual shipping (it's 27 lbs. on its own without packaging); much prefer pickup in Los Angeles.
Yamaha page:
https://usa.yamaha.com/products/proaudio/power_amps/p_series/index.html
Yamaha specifications:
https://usa.yamaha.com/files/download/other_assets/0/322310/P-S_datasheet.pdf
Specifications:
26 lbs.
500 watts RMS at 8 ohms per side
700 watts RMS at 4 ohms per side
therefore
1400 watts RMS bridged mono at 8 ohms
Both binding post and Speakon connectors
sweepable low-pass or high-pass filters for running a bi-amplified application from 25 Hz. to 150 Hz.
« Last Edit: 25 Aug 2019, 10:44 pm by taloyd »
taloyd
Amplifier still available; happy May Day everyone!
-Tal
taloyd
Happy June everyone!
This is particularly good for subwoofers - bridges to 1400 @ 8 ohms mono, and has a sweepable high-pass/low-pass filter (though the high-pass only goes as low as 25 Hz., due to the intended nature of professional audio. That said - it'd practically be idling in a home environment - unlimited dynamic range!)
