So, what might this mean for the average audiophile like me? Let’s take just one example. My very best digital recording is a Mercury SACD of Rachmaninoff’s 3rd Piano Concerto played by Byron Janis. The original recording was made in 1960. But I also have the same recording on vinyl. I had a group listening session a couple of weeks ago in which I played both versions. The result: everyone preferred the vinyl version.
This is a decent oscillator at 45 and 49MHz, but not at 24 or 22MHz.Try this one instead:https://www.mouser.com/datasheet/2/94/CCHD-575-18036.pdfSteve N.
Looking at the two datasheets the noise floor for the first unit is 7dB lower noise at 10Hz than the second datasheet for the 22MHz and 24MHz parts. Why would it be better?
Nothing magic about it.Mouser...................Digikey....... ........others...................http://www.crystek.com/crystal/spec-sheets/clock/CCHD-957.pdf
It's the phase jitter that is highest that will be audible,
not that at 100KHz which is the "noise floor". Nobody can hear -165dB or -170dB.Steve N.
?????Oh, really.........................Then why do guys like you rely so heavily on measurements that are really nothing but the noise floor? (That is what your fancy Tek 'scope does, whether you want to admit it or not.)What you fail to realize is there are other metrics, that determine a clock's suitability, for use in a digital audio system. The phase noise is just part of it, and is the easiest to comprehend. (The folks that build these parts know all of this. They also know what the "magic numbers" are, for all of those other bizarre and obtuse metrics. Why do you think they are willing to work with such a PITA like me? Because I know this stuff, and have the understanding which ones are important and why they are important. And more significantly at what level they are important.)But you guys feel free to brag about how many fSec of jitter that your stuff has, based on the noise floor specs.
The period jitter distribution is not the noise floor. All of the metrics, including phase noise plots, period jitter distribution plots, period jitter spectrum plot and listening tests are needed to fully characterize the jitter.Steve N.
Because it gives a "double-hump" histogram. IOW, it is the kind of result one would see if there is "deterministic" or "correlated" jitter present. (A good example of this would be mains-related crud getting into the clock supply, and mucking things up.)
