Great thread, Pat, which pretty much convinces me that the standard DIY approach of ordering a couple of clocks off of the worldwide web and replacing existing ones in a DAC or USB interface is a complete crapshoot.On a positive note, it means I can just use the vacuum cleaner to pick up the ultra-tiny NDK clocks that have disappeared somewhere on the floor near my work area.
Pat3 questions from an idiot;
1 TempKnowing that temp variations affect jitter, how does it affect jitter. Is it he variation over a short period of time? Like have the furnace or AC turning on and off and the clock is not covered well. Or is it the base temp, like having the house at 68F in winter and 72F in summer. Do we care about the base temp once the temp has stabilized?
2 PowerA clean supply to the clock is crucial, we know this. How does this translate? Is there a PSRR number , or similar, for clocks based on frequency? Assuming we don't want to use a 3 pin regulator is it because the high frequency stinks or is it because the output voltage can drift vs temp?
3 OscillatorAt another forum there is much talk about buying good crystals and they are using the crystals in different oscillators. Being 30+ years since I've used my FCC license or looked at RF oscillators, can you explain some the whats, whys, and the don't do this unless you're a huge idiot....Mike
Art, thanks for your reply.Looks like I have some digging to do.1. Does my Ayre QB-9 use a DAC chip that does everything async?
2. What clock is in there now?
3. How hard would it be to replace?
4. Where does one find the magic $30 replacement?
There is an external clock system that M2Tech made many years ago to drive their XMOS USB to S/PDIF, I2S, AES/EBU interface box.
There was an external switch that selected the clock family that was to be used for what you were playing. A bit more manual than most probably like. It used a 50 Ohm coaxial connector output with RF cable between the two units. I have one here. Is there a way to measure the unit for a possible upgrade?
Nothing magic about it.Mouser...................Digikey....... ........others...................http://www.crystek.com/crystal/spec-sheets/clock/CCHD-957.pdf
