0 Members and 1 Guest are viewing this topic. Read 51941 times.
Okay, got it. So it's just the crossover on the Maggie's themselves. Yeah the LRS's go to 50hz so I would cross the sub over at 50. And yes, for sure going with sealed subs, either Rythmik or REL. And from everything I have read and heard AVA stuff is VERY good and legit. I have talked to Frank on numerous occasions and he is so helpful and loves what he does. I know he would take care of me if there were any issues but I would love for his seasoned guy to build my amp. But by the time I get around to ordering one of his amps, the guy will be seasoned. I think the route I am going to take for now is going with the PS Audio Stellar S300. All I keep reading is spectacualar reviews on it. And how it sounds more tube like than Class D. Very warm and musical, kind of the way you described the SET400. Steve Guttenberg paired it with his Maggie .7's and said it was a match made in heaven. https://www.cnet.com/news/get-ready-to-upgrade-over-receiver-sound-quality-amplifier-preamp-power/Also they have a trade in program, so I can unload the NuForce STA-200, which I have no use for and get $450 off the S300. So that puts it at $1049 or something like that.Then I can do one of two things. If it's still not enough power for the Maggie's I can move it to my system with the ZU's and order the AVA SET400. Or trade it in for the Monoblocks from PS Audio. For sure the smartest approach and fastest. I can get that within the next couple of weeks. If I get the SET 400 we are talking a couple of months.
You should have no problems with powering the LRS's with 300wpc. When you get a sub, play around with the crossover points, you may like it crosses over any where between 50 and 60hz. If the Maggies are a little close to the side walls or corners you may get a little deeper bass. Play with toe in and spacing. Even 1" can make a difference. They do have a small sweet spot however. And don't pass judgement until you have at least 75 hours on them. If you like acoustic music, piano and vocals you will love them.
Yeah, 300 watts should be more than enough. Even though the 80 watts I have now sure isn’t enough, the Maggie’s still sound great with just that. I can’t imagine what 300 watts per channel will do to them. And I always play with the settings on the crossover on subs to tweak it just right. Won’t be for awhile until I get a sub for the Maggie’s. First up is amp, then pre, then CD player, then some subs. As far as the Maggie’s being close to the side walls and corners, on the office room they are a lot closer. And I have for sure noticed a significant difference in bass response compared to them being in my open living room.But what I have noticed now in the smaller room, the soundstage has shrunk and the music and instruments don’t seem to float around the room and air as they did downstairs. They still sound great and image well, just not as magical as they were in an open area. Maybe like you said, I need to play with them and positioning some more. I feel a little lost right now and that I don’t know what I am doing. I don’t even know exactly what I should be listening for to know they are just right. Someone come and help me set them up! Lol
I've found that depth is a function of how far they are from the front wall. 3' minimum and as you pull them further out into the room the sense of depth continues to increase.As you say, if they're close to a side wall, they develop more bass, sometimes too much. There can also be issues with the front corners in a small room.I think the main tool for dealing with a small room is diffusion. I find it works very well in the front corners, with the diffusers forming an equilateral triangle with the two walls. Also, if you put diffusers behind the speakers at the first reflection point (the point at which you see the rear of the speaker in a mirror from your listening seat), it will make a small room/close placement behave a lot more like a large one/more distant placement.
Have you thought of a used Parasound integrated which should be available for about $1500. I had one with my 1.7i and they sounded amazing together. The Parasound is a Stereophile rated A component with plenty of power 240 watts into 4 ohm and is a 2.1 integrated making it easy to add a sub.
I have them about 38 inches from the back walls. And depth isn't an issue. The sound stage seems deep. And for sure the bass is more dominant in this room, not over bearing though, I like it and it sounds good. I am just going to play around with placement like you suggested. And s far as a diffuser goes, where would I go for that? And would I get something that is as tall as the speaker itself?
I am not a fan of the Parasound preamps except for the JC2. I have a friend that had a Parasound P7 and it was dry and grainy. He just replaced it with an Atma-Sphere MP-3. If you want a Parasound P6, them buy a used JC2, you can find them for about $2K-2.5K.Dead quiet.
Looking good. You may try if you desire removing the "U" connector at tweeter attenuator and replace with a piece of speaker wire you are using. Then maybe an upgraded fuse like SR Blue. Enjoy your new speakers.charles
Congrats. Looking forward to your impressions.
What does all of that do?
Less grainy, smoother top end, improves vocals, better dynamics and bass. Break in your speakers for 300 hours then try some tweaks one at a time. Have fun trying. charles
