Low profile speaker lift / jack
0 Members and 1 Guest are viewing this topic. Read 5791 times.
brj
Re: Low profile speaker lift / jack
« Reply #20 on: 11 May 2019, 11:26 pm »
Yep, I figured this wouldn't be an easy ask!  :D
As mentioned, I already have isolation platforms under the speakers, and I'm impressed enough with them that I don't intend to change them out.  (On my suspended wood floor, the difference was quite noticeable.)  I don't really need to move the speakers, just be able to adjust the isolation footers and fine tune the aim, so lifting in place is enough.
I'll watch for the release of the IsoAcoustics lift, and if that doesn't fit the bill, I may try the one I linked originally.  (Perhaps I can swap the small head on it for a larger, flat one.)  Or maybe I just find the local Wilson Audio dealer and see if they have one of the Wilson lifts that I can borrow/rent.
Thanks.
sunnydaze
« Reply #21 on: 12 May 2019, 01:57 pm »
I'm having trouble visualizing your current situation.  Is it just me?
Perhaps a photo or two of your current bases / isolation devices / or whatever it is your speakers are sitting on would help generate better suggestions.  I mean, everyone has a cell phone....no?
guest61169
  • Guest
« Reply #22 on: 12 May 2019, 10:38 pm »
No it's not just you!
