Audio/Video Gear and Systems
Owner's Circles
Channel Islands Audio Owners
CIAudio
5VDC-SB voltage conversion
Michaelch33
19 Mar 2019, 12:25 pm »
Dusty, please tell me 5VDC-SB if it has a voltage of 120 volts, can it be converted to 230-240 volts?
CIAudio
Facilitator
Re: 5VDC-SB voltage conversion
19 Mar 2019, 01:13 pm »
Yes, the older VDC•SB uses solder-in jumpers for voltage selection.
We can do it for you, or email us for details.
Michaelch33
Reply #2 on:
19 Mar 2019, 06:06 pm »
thank you for answer, think I can do it myself
CIAudio
Facilitator
Reply #3 on:
19 Mar 2019, 07:48 pm »
Just remove the 2 jumpers in the 120V position, and place a single jumper in the 240V position. Once opened up, you'll see the voltage markings on the pcb.
Michaelch33
Reply #4 on:
20 Mar 2019, 08:56 am »
Clear, thanks Dusty!
Owner's Circles
CIAudio
